windshield wiper blades
Maxx
astrand1
Alex
Studio truck driver
Hmmm... have the Bosch Icon and RainX blades always been that expensive? ~$30 per blade? That's crazy. I think I will probably just go with the Costco special... Michelin blades for $6-8 per blade.
So I got a set of these last year. What I noticed was that they starting lifting up at speeds above about 65ish. I thought maybe they were bad so got another set. Same result. My buddy also has an f150. He got a set and had the same issue. Just an fyi.
Scorpio3d
SS/IBA car wash owner
I have used the Costco Michelin blades on my previous vehicles (Expeditions)! they are quite decent wipers and tend to last a while! You can replace a lot of blades for $30-$60!
wighty
NY
I haven't noticed that myself. Is this when the wipers are being used or is it happening when they are "tucked in"?
ZheWiz
Jack
Central NY
Database developer
Bosch Icon 26ā€ blades passenger and driver. No rubbing, clears much more, doesn’t look goofy. Seems like the size they should have used.
astrand1
Alex
Studio truck driver
Just when they are in use. As they are on the return about half way down the driver one will lift off just enough that it is not wiping. This was over a year ago so it’s possible they might have changed design just a bit. ?ā€ā™‚
