Pre Departure Conditioning on App does not happen
1Jetpilot
Jerry
Port Clinton, OH
2023 F150 Lightning Lariat ER
Retired Pilot
On the Pass App, went to Energy>Departure Time and put in the time I planned to depart for a preconditioning in the morning. Today is the morning and nothing happened and no evidence of a pre departure conditioning. What did I do wrong?
My scheduled session for this morning did not happen, so I pushed the button myself.
Probably another data center glitch ?
1Jetpilot
1Jetpilot
Jerry
Port Clinton, OH
Retired Pilot
I mean I do not think I did anything wrong or did I? I just put in my departure time and the rest should auto start shouldn’t it? Out of curiosity, what button did you push when you noticed the pre conditioning did not happen?
MrLoganRoss
Logan
Seattle Washington
Mine is working ok this morning.
After shutting down (force stopping) the app and reloading the app to confirm no latency in vehicle status, I clicked the large button with the fan image on the Vehicle tab.
After about 20-30 seconds the button showed the animated fan icon indicating the climate system had started.
Remote start worked perfectly yesterday.
BTW, the setup process is a bit convoluted, make sure you've set up the time & conditions screen and click SAVE. Also verify that the OFF PLUG switch is ON if your truck was unplugged, If you want to create another routine for a different time frame, click the + [plus] icon and begin building the new scheme, remember to click save to commit it to the cloud.
Ford F-150 Lightning Pre Departure Conditioning on App does not happen 1728397162498-0u
I added an afternoon routine to see how it works later today and the rest of the week.
Ford F-150 Lightning Pre Departure Conditioning on App does not happen 1728397545263-g
The departure time event did not start the truck this morning, I manually started it after confirming the tail lamps were not lit, I sent a lock command which worked, then pushed the start climate button.
1Jetpilot
1Jetpilot
Jerry
Port Clinton, OH
Retired Pilot
I set the departure time last night and, again, nothing happened this morning. With my Tesla, everything worked every time.
Ford F-150 Lightning Pre Departure Conditioning on App does not happen IMG_1077
Ford F-150 Lightning Pre Departure Conditioning on App does not happen IMG_1076
Are you plugged in overnight?
If so, is your EVSE limiting energy availability around the 7:30 am time frame ie. {OFF} ?
1Jetpilot
1Jetpilot
Jerry
Port Clinton, OH
Retired Pilot
Yes, plugged in, I turn off the environmental since the temps here are mild
bg226
Bryan
Anaheim
Mine won't save the departure time. After adding the new departure time, it spins for a bit then stays on the Add Departure Time screen. If I leave and come back, it's not saved. This is the Android version of Ford pass.
@Ford Motor Company we have a bug.
1Jetpilot
1Jetpilot
Jerry
Port Clinton, OH
Retired Pilot
mine always saves but does not activate at the designated time
Try adding it in the truck via the Sync screen, then see if the scheme is visible on the app.
Could be a cloud/server issue or configuration of your permissions in the truck.
EDIT: One more thing with ANDROID, force stop and clear the cache (not the data), then restart the app
1Jetpilot
1Jetpilot
Jerry
Port Clinton, OH
Retired Pilot
I googled this:
No, your "Prepare Cabin Off Plug" does not need to be on for a Ford Lightning to be preconditioned at a specific time; you can schedule preconditioning through the FordPass app or your vehicle's SYNC system, and the car will automatically activate preconditioning based on your set departure time, even if the "Prepare Cabin Off Plug" is off.
