Sport Mode all the time
Lytning
Georgia
*As long as you avoid accelerating at the exact same speed as gravity while utilizing or generating zero electricity. That mode usually results in harming the truck.
It is actually the following rapid deceleration which results in the harm.
Zed
Chuck
2022 Lightning Platinum Rapid Red
Ford F-150 Lightning Sport Mode all the time Screenshot 2024-11-03 070106
Really?? Unless they've put air suspension on the 2024 Lightnings, this is just totally incorrect. Written by a salesperson, apparently. There's another place where it mentions that sport mode changes suspension stiffness....
I agree that Sport Mode has some useful features, but a Ford dealer posting these kind of factual inaccuracies makes me sad.
I agree that sport mode has some useful features, but a Ford dealer posting these kind of factual inaccuracies makes me sad.
Do we have active dampening ????
Reactions: Zed
Zaptor
2022 Lightning Lariat ER ZAPTOR 2025 MME GT RALLY HABOOB Kubota L3560 Goats wut
.......... Trophy husband
100%, now it has me doubting the veracity of the rest of the article, since it is unsourced...
-Zap
Zed
Chuck
I have never seen anything about having that. I would think if we did, Ford would be making noise about it being there. I remember looking at the rear shocks when I installed the splash guards and did not see any actuator or electrical connection on them.
Zed
Chuck
I wouldn't be too upset, Ford did have active suspension available for the Lariate and up however I do believe they discontinued it. He is wrong about the lightning, but that may just be outdated info.
According to this R&T article, active damping was introduced with the Gen14 trucks:
https://www.roadandtrack.com/news/a36276736/2021-ford-f-150-updates/
But Google AI says no active suspension on the Lightning:
No, the Ford F-150 Lightning does not have an active suspension system, but it does have an independent rear suspension
Zed
Chuck
Sorry, I didn't clearly state "for the gas trucks", i see how that was ambitious.
I don't believe it was ever offered on the Lightning, it was available on the Gas trucks for a while however.
Understood and agreed!
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
I drove about a year in "normal" mode. Now I have driven several months in "sport" mode while in town. All on the same roads and spanning various weather and traffic conditions. I have found about a 5% increase, from say 2.0 to 2.1 in efficiency while using "sport" in town.
The 5% could be equal to, or at least partially due to the number of times I used some friction brakes during a unexpected stop in busy town traffic. The "sport" regen fits well with my driving such that friction brakes are never required until I come to a complete stop.
I don't like sport on the open highway in light traffic where the "normal" regen equates well to ICE compression from my decades of driving, it is just too jerky.
Jseis
Washington
I use Sport because of steering feel. If you want good steering feel, pump your tires to 45 psi. I drive mostly rural roads at 45-58 mph & long term winter-summer average is 2.4 mi/kwh. As soon as it gets icy in the morning I’ll switch to Normal & no 1-pedal which I’ve learned to dislike.
OMO7
23 Lightning
Do you disagree?
There's no agree or disagree. It's true or false.
Take 2 identical trucks to a drag strip and run them each 5 times. The 1st truck you floor it every single time. The 2nd truck you accelerate gracefully. Do you really think that after 5 runs they're going to use the same amount of energy?
Incase you still don't understand lets compare it to something that everyone can agree on. You get better mileage going 65mph than you do going 80mph. By your logic both trucks should use the same amount of energy because at 80 mph you're driving for a shorter period of time.
Traconesu
Patrick
Quad cities, Illinois
Ford lightning platinum
Whether you accelerate from 0 to 60 rapidly, or slowly, you use the same amount of electricity.
None of the modes harm the truck.
You can't be serious. If you get from point A to point B at 70 mph versus 55 mph of course you'll use more power out of your battery.
Traconesu
Patrick
Since you had to bring a condescending tone into it we will go ahead and keep it that way.
Your two arguments show you don't understand the point at all.
In the drag strip situation of course the truck that accelerated slower used less energy, it reached a lower speed. It went from zero kinetic energy to a value LOWER than the truck that accelerated the whole way, of course it expended less energy doing so, it's final kinetic energy is lower. But that's not how people drive, they accelerate up to their predetermined speed. That may be 35 after leaving a stop sign, or 75 on an on ramp, in the end their final speed isnt determined by how hard they accelerated to get there.. In both cases they used a set amount of energy to go from zero potential energy to the SAME kinetic energy. Read up on the conservation of energy if you don't get this. If two vehicles have the same efficiency and weight you cannot put more energy into one than the other and still end up at the SAME SPEED.
As for your 60mph argument vs 80, that shows you don't even understand that the conversation is about energy at all. If between two trucks one of the truck went half as fast and that use HALF THE ENERGY PER MILE, and completed the trip in twice the time then yes, they would both use the same amount of energy. But that isn't how it works, the amount of energy needed to push something through the air is exponentially higher the faster it goes, so the truck going twice as fast uses FOUR TIMES the energy. But in the end that has NOTHING to do with acceleration. You seem to have gotten lost on the time component and didn't think about what is being discussed.
Physics 101 tells you that ignoring efficiency the amount of energy you put into a system results in the same end case, you cannot put more energy into one of two identical systems and yet reach the same end point. What CAN happen, and what does happen, is that in ICE vehicles the EFFICIENCY changes depending on power output, in that case less energy goes into accelerstion and more into heat. This is not the same for EVs, and although system efficiency MAY change the harder you accelerate the difference is very small. In fact I expect the biggest difference would likely comes from the fact that the faster accelerating truck spends more time at a higher speed than the slower accelerating one, but since you are speaking of seconds on a trip that takes tens of minutes the difference is miniscule in comparison to energy expended elsewhere.
What a bunch of BS. When I drive the interstate at 55 mph I get 2.3 mpk when I drive that same route at 70 mph I get 2 mpk.
If I accelerate slow to 55 or 70 or accelerate fast to 55 or 70 I use even more energy accelerating fast and may not even achieve the 2.3 mpk @ 55 mph.
Altivec
I definitely see an improvement in efficiency in sport mode over normal mode. It's probably due to the slightly more aggressive regen. Instead of coasting and braking in Normal, I am assuming it sits in regen for a few seconds longer each time I brake. I think you will notice this more if you are a city driver doing a lot of stop and go. I doubt you will gain much in sport if you do long distances.
I also like the steering feel and pedal mapping better in sport but I stopped using it. Just got completely annoyed of having to be so attentive starting my truck in anticipation of hitting OK to keep it in sport. I really wish Ford would fix this so I can go back to using Sport. I would take that fix over Karaoke 1000 times over. If you're listening Ford, drive mode should be tied to each user. My wife prefers normal and I prefer sport. Each of us, should resume to what mode we were using last.
Amen @Ford Motor Company real value updates!
