What Level 2 charger do you recommend
TitanGuy
carlos
Los angeles
2024 Lighting Lariat Antimatter Blue
Sales Rep
New owner of a WR Lariat here. So I’m planning on running a 220v 60 amp breaker for 48 amp charging. What do you guys think is the best charger option. I can get the ford pro station for about 500$ off FB. What would be some other option.
Shawnson
Edmonton
Lightning Lartiat ER, Model 3 LR, Crosstrek… hehe
Developer
Charge station pro is a little annoying because of the CCS adapter and having to flip down the DC pin cover. Universal Tesla Wall Connector would be my recommendation.
tls
New York
2022 Lightning
Tesla Universal Wall Connector would be my choice for a truck with 48A onboard charging.
pullinggs
Alta, CA
'23 SR XLT, '24 Flash
Lots of good options...
I have an Emporia EVSE installed on my wall (love it) that can deliver 48A max charge rate. But I never seem to need to charge at 48 amps. It turns on at midnight at 24A and the truck is ready to go when I wake up. Yes, if you've run your battery down really, really low then you'll need more than 8 hours @24A to get back to 100% state of charge (SOC). But most of us practically never do that. Don't get too hung up on that max rate of charge unless it's really that important to your use case.
Jseis
Washington
I’ve a CP HomeFlex on a 50 amp breaker charging at 40 amps. I’ll probably upgrade the wiring/breaker in the future and kick the charging amps up. Currently it adds about 9kw/20 miles an hour and puts 30-40 KW back in the truck in 4-5 hours. We don’t have off peak rates but if you did, charging from 12 midnight to say 5 am might be worth it and charge at a higher amperage. The HomeFlex has worked great the last 18 months. I positioned it in the garage so we can also charge the Mach E if need be.
iam-s-Hon
Richard
2021 Job 1 MME Premium AWD ER Iconic Silver, 2024 Lightning Lariat AMB
No issues with my CP HomeFlex (40A on a 50A breaker). I have solar panels plus TOU rates. I typically run 16-24A during the day to stay under my panel output. I can adjust the amps in the CP app to align to solar curve and use the target settings in FP app to stop/start as needed. I have mine setup to auto charge off-peak. However, I don't always charge overnight if I don't need it and have a sunny day the next day. I work from home so do more driving on weekends and have the following week to charge back up. Will now need to rework my garage for 2 EVs, one being the truck that barely fits.
invertedspear
AZ, USA
lightningcalcs.pages.dev
Check with your power company. They often offer subsidized chargers. I got mine for about half MSRP. See what choices if any they offer, let us know and we’ll help pick between them.
Further, avoid EnelX/Juicebox chargers. The company went bankrupt. While the chargers are fine as dumb chargers, the connectivity and app could go offline any day, since some other company is keeping their servers going.
RickKeen
Rick
F150L SR Pro
sw engineering manager,
I would second the suggestion to check with your power company. They may be able to offer discounted electricity for charging with some chargers that they support.
Outside of that, I really like the Emporia. Comes in J1772 or Tesla versions. I am assuming either version could charge the other type of vehicle with the appropriate adapter (but you should confirm that if that is something you need). I just have the J1772 version for my Lightning.
I like that it integrates with my Emporia home electrical usage monitor. Also cheaper than the Tesla universal charger.
jetfixr1
Anthony
Atlanta
2023 F150 Lightning Lariat ER
I love my classic Grizzl-E! Its the only EVSE I have found to be fully enclosed in metal. IMO, in case of a fire on the unit, it will be fully contained and keep my home safe. I have one year of use on my current one and it works like a champ.
EDIT: I now regret browsing their website. I saw they have a new 80 amp charger, and I want it so bad . My Christmas gift might be upgrading my wiring and buying it....:crackup:
after 50,000 miles over two years, I've used everything from the simple 120v option with the Ford Mobile charger, a 20amp 240v EVSE we've had for several years of Nissan Leaf ownerships, the 30amp 240v option with the Ford Mobile charger, and a EVgreen 30amp 240v ADJUSTABLE EVSE.... all do exactly the same thing - charge your truck battery.
Generally, there's no big hurry to most everyday overnight charging, although it might 'seem' that you need more than that... 30amp 240v is the norm, but some will expect more. 99% of my charging for all my miles is from home, from the Ford Mobile charger - it works.
inchman254
Collingwood, Ontario, Canada
F150 Lightning Lariat, Kia Telluride
I've been using the Emporia charger for about 6 weeks and find it works as advertised but I don't have anything to really compare it to. It charges at the advertised 48 amps/ 11 kw. It comes with a NEMA 14-50 plug already attached that allows up to 40 amps / 9.6 kw. It's easy to convert to a hardwired arrangement to get the full 48.
The biggest complaint that people seem have is the diameter and weight of the cable and the adapter holster but that is supposed to be updated in future versions. I hang my cable on handlers from the ceiling so it doesn't affect me. The adapter hangs right beside the charge port.
I also use the Emporia home energy monitor so it ties right in to that.
Jetfixr1 indicated that he wants to upgrade to 80 amps which is great for his 2023, but 2024s can't handle that high an AC feed as they don't have the dual on-board transformers.
iam-s-Hon
Richard
FWIW I’m less aware of failures within the evse than stories about failures at the outlet based on posts in the MME forum. Ive been thinking about swapping my CP for an Enphase to pair w my solar controller. I have a plugin and they ship theirs with a Hubble plug b/c other commonly installed ones are inferior for charging. I checked and have a cheap one, but I rarely charge at full power for an extended time.
TitanGuy
carlos
Los angeles
Sales Rep
what’s the rationale for only charging at 24amps?
flyct
Jerry
South Florida
Blissfully Retired
I vote for a Tesla Universal Wall connector hard wired to a 60 amp line. It has BOTH CCS and Tesla connector on the end of the cord which future proofs your installation. Eventually every EV will have the Tesla NACS connector.
The Tesla Universal Connector can be configured anywhere from 12-48 amp output (15a-60a circuits) It has a 4 year warranty.
