Any suggestions - taillight repair
bosox8
Charles
Sales
So this happened this morning - called dealership and they said $2,300 - any less expensive fixes / suggestions? Everything works fine - just unsightly broken plastic.
Ford F-150 Lightning Any suggestions - taillight repair 1733146660769-f6
Note that inside there are sensors that need to be transferred to the new lens if you find one. I also THINK that it's (the lens) specific to Lightnings, and perhaps Lariats and above, but not positive on that.
Get replacement on eBay. Note there are two styles. You need the Lariat/Platinum style. Not Pro/XLT Style. Difference is the reverse light and how the tailgate meshes with the light. Lariats/Platinums have a different tailgate.
Then move your BLIS sensor from the old light to the new one. If you don’t you will have to have the dealer program the new one. Easy swap, three torx screws.
husky10101
E Wa
2018 F150 diesel & 2023 F150 Lightning Lariat
I had mine broken and I taped it with red tape and then spread clear silicone on it to make sure no rain gets inside it until I got it repaired. If the sensor inside gets wet then it is ruined and you will have to buy that also. Was kind of ugly for a bit but it stayed dry. Seems nuts the lens is $2,000.00 without the sensor which I feel should be the expensive part.
More info:
BLIS sensor location. Three T-20 torx screws.
Ford F-150 Lightning Any suggestions - taillight repair 1733152149681-xf
Tail Light styles
Pro/XLT on top (flush mount rectangular reverse light)
Lariat/Platinum on bottom (recessed trapezoidal reverse light, covered by tail gate when up)
Ford F-150 Lightning Any suggestions - taillight repair 1733152597514-1f
Ayrshireman
Glyn
Brewerton NY 13029
VW Taureg and Subaru Wilderness
Sales Management
Went through this tail light nightmare also. Ended up paying $2300 at dealership to replace. Explored eBay and other options to no avail. Sorry.
bosox8
Charles
Sales
yeah, just got a 2nd quote for essentially the same - outrageous need to replace whole tail light assembly for broken piece of plastic
The Weatherman
Dean
South Central KY
You might find something in the salvage arena. I would look in the larger EV adaption marketplaces. California, TX and FL come to mind.
rockhead
Glenn
BC
F150 Flash
Geek
I got 'lucky' and found one for mine at a wrecker. If I'd had all the plastic I would have attempted a taillight wrap
ddimit
Sacramento, CA, United States
2015 Tesla model S 2023 F150 Lightning Lairat
Manager
The design of these is just awful, thin plastic protruding beyond the fenders/tailgate is just a recipe for disaster.
bosox8
Charles
Sales
Follow-up: new tail light installed - replacement light now has a connector pin I’m assuming for direct trailer connection? Also - this is a PnP light - dealer wanted over $200 to remove two screws and swap out.
bosox8
Charles
Sales
So now no cross-traffic / blind spot usage - simple fix?
bosox8
Charles
Sales
Thx!
