! Not Completed (OTA updates)
PJnc284
Garner, NC
I just went outside to observe my truck and it sounds like a swarm of bees is underneath of it.
Is this a normal part of the upgrade process? I have never noticed it before
normal. And lol, I had to look up what a pocket pod mini is but looks like that might be cheaper. Mongoose I was referring to is used with FDRS to update modules instead of waiting on Ford's finicky OTA process. Amazon.com: Opus IVS Mongoose-Plus J2534 OEM Vehicle Interface Cable - Ford/Lincoln/Mercury OEM Reprogramming and Diagnostics : Automotive
tearitupsports
Russell
Houston, TX
Doesn't charging the hvb charge the 12v? Mine was off the charger since Sunday and noticed the 12v was reporting about 64% in CarScanner so I plugged it in Friday and it reported a 100% charge on the 12v when I checked this morning. Seems like a big drop in a few days but has been cold this week. I've had the battery sensor replaced so I'm wondering if I just have a bad battery.
The 12V battery only actively is charging while the truck is on, or the truck is actively charging (not just the cable plugged in). For instance if you have the FCSP charging at 19kW, you actually don't get a good charge on your 12V battery sometimes, because once you hit your charge limit it also stops charging the 12V battery.
The best way is to leave the truck on for like 8 hours (turn off lights, radio, AC, etc.), or plug in a level 1 charger overnight, or set the charge rate really low if you have an adjustable level 2 charger. Those 3 things work great for getting the 12V SOC up high.
jakes_02
Jake
Tennessee
23 F-150 Lightning lariat ER
IT Business Automator - Owner
I have never noticed the sound on any other update, though this is the first "Major" I have received. (If we consider 1.4 major)
HA HA HA HA HA HA HA... I thought you were joking that you downgraded your EV to an EV Mongoose Bike... LOL....
I live in a small town and the local auto shop has said I could swing by and use their stuff and this was as close as I was to taking them up on it so I didn't have to purchase the other equipment. Purchasing ForScan was easy and I already had the OBDscanner
Ffxdude
22 Lightning Lariat ER
If you do not, unplug the negative cable off your 12v battery and wait 20 minutes before reconnecting to force reset the modules. Then start the truck and check for updates to see if it'll download the files.
After reconnecting the cable is there anything special that needs to be done to get the frunk to close? Do we just push the button to close or manually close and then push button to open it normally?
Scorpio3d
SS/IBA car wash owner
This is common after unplugging your 12 V battery. You just manually pull it down and get it closed and it should latch then it should work properly after that.
Ffxdude
Thanks, I'm going to give it a try. Going on 2 weeks with the stuck update.
Does the screen say "not completed" or is the OTA trigger still active and failing to install?
Ffxdude
Not completed. I think it initially attempted when my LVB charge state wasn't that high.
Ford F-150 Lightning ! Not Completed (OTA updates) 1000235854
That sucks.....that means the OTA failed....it is not stuck. There's nothing you can do at this point but wait for it to be resent.
Ffxdude
Bummer. Thanks for the clarification though I misunderstood that the fix was for failure not stuck.
Iceberg000
MIchigan
2022 F-150 Lightning Lariat
Not the battery you drive on....the battery in your frunk.
Could you please check my VIN to see what updates are available? My truck is a 2022 F150 Lightning VIN- 1FTVW1EV5NWG#####
Gladly, but please remove your VIN from your request. Modules with pending updates are below. Your truck is on the latest Sync software and the ADAS modules are also on the latest version. In terms of the more important modules, you are up to date.
Ford F-150 Lightning ! Not Completed (OTA updates) 1743883844606-bu
Iceberg000
MIchigan
Can you tell if it is going to get the bluecruise update 1.4? Is there a way to encourage the truck to get all of the updates?
memoag12
Guillermo
Costa Rica
Lariat 2023 ER Max Tow
OTA updates have been stuck in power up 4.2.3.1 not finished, no AT&T signal at my place, Wi-Fi is connected.
Connect a battery maintainer 8amps overnight to try to trigger the OTA and nothing. Read somewhere I need at least 15Amp so I am trying again but not sure, should I close the frunk, lock the car, while connected to the battery maintainer?
Any other suggestions to receive the updates.
Heres my VIN number in case anyone can check whats going on,
Maybe @rugedraw can you help me check?
2023 Lariat ER
2023 Lariat ER
Gladly, but please remove the VIN from your request.
That GWM has been sent twice to your truck, and both times the OTA failed because the truck did not ping the server back to accept the OTA. Right now, it shows your modem is not authorized on the network which means your truck is not talking to the cloud. If you live in an area with no cellular data, this will affect your ability to get updates OTA. Wifi is not required or used for 99% of Ford OTA updates. Your truck is was exported to Costa Rica and your modem is provisioned for the United States. I assume Ford does not support OTA's in that country, so this will continue to happen. The only way you will be able to update your truck is by investing the tools needed to do it yourself.
Ford F-150 Lightning ! Not Completed (OTA updates) 1745601860929-vo
