Tonneau covers recommendations and pics?
20acrefarms
Scott
Enniskillen Ontario Canada
2019 VW Atlas, 2021 F150 XLT space white
Industrial Fire Fighter
Hello everyone. Was hoping people would post pictures and specs of their tonneau covers. Maybe even add some pros and cons.
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
There's a subforum on just this topic with several reviews on different makes/models/styles already
Platimatter
MO
2021 F150 Platinum 701
Check out the undercover ultra or armor flex. Both are tri folds. I went with the ultra fir the smooth surface. The armor is coated with Linex. If you want a roll up look at the back revolver x4.
Ford F-150 Lightning Tonneau covers recommendations and pics? 0CC0EDB4-0A4C-4BCD-B3B5-139B5895D71A
clayjoe
Clay
San Antonio, TX
2021 F150 XLT PowerBoost Antimatter Blue two-tone
Teacher
I like my Bak x4s. There are pictures on another post.
*edit link to post:
https://www.f150gen14.com/forum/thr...lver-x4s-tonneau-cover.2583/page-4#post-42968
Pros:
Easy install
All black high-quality design. improved upon the x4 model.
Can see the rare tail light and use the bed camera when rolled up
Quality powder-coated aluminum rails front to back
Looks great
Logo sticker came right off
Super low profile
Does not take up bed space when rolled up
No prying eyes on my stuff(keeps more honest people honest)
Oversized
Through a few washes and has yet to show any leaks.
Keeps stuff out of the bed
One solid cover as opposed to 3 or 4 panels
Cons:
Where they cut vertical rails attached to the truck are rough/ looks low quality
Security is there but I feel I could get in if I wanted to rather quickly
One of my sides is slightly higher than the other by like 1/32 if that much
Lippy
CA
2021 F-150 Powerboost
LoMax trifold. Very sleek and high quality
NH_Leadfoot
Geoff
NH
2021 F150 XLT 302A
.GOV
I have the Undercover ArmorFlex on mine, love it so far. The bed stays dry unless I pressure wash under the tailgate.
daemonic3
Terry
Sacramento, CA
2017 F150 3.5EB
+1 from me for the Lomax Trifold tonneau
pros (for me):
  • 30 minute installation
  • No drain tubes
  • Urethane finish matches spray-in bed liner
  • No tools or loose parts to remove, uses quick release to fully remove
  • Amazing deal out the door from truckalterations.com if you mention you are a forum member
cons (for some but not for me):
  • Half inch profile (as opposed to zero profile like bak and undercover)
  • No propped position against window (the Lomax Stance has this though)
Here is the thread you want where it is covered ad nauseum: https://www.f150gen14.com/forum/threads/factors-to-consider-before-buying-any-tonneau-cover.693/
And one specific with pics of the Lomax: https://www.f150gen14.com/forum/threads/lomax-hard-tri-fold-installed.2549
Corsini77
VA
2021 f150
Retrax Pro MX.
Pros:
High build quality
Lockable at any position
Keeps all water out except for near tailgate if pressure washing.
Sleek and low profile
Aluminum panels are strong for strapping cargo on top
Cons:
You do lose some bed from the canister
Price
Ford F-150 Lightning Tonneau covers recommendations and pics? 694F1A5A-7867-467A-8B38-0C2AA140CC5C
Hudnut
2021 F150 Platinum
Auto industry
I have the Retrax pro XR and confirm the pros and cons above. another con though is that you can open the cover while the tailgate is closed and locked. this means you have to lock it with a key if you want the bed secure.
Vulnox
Livonia, MI
Bakflip MX4
It looks great, has worked flawlessly, and the best thing I can say for it is I have had it since my 2017 F-150, then it went to my 2019, now my 2021. In that time every one of the trucks has sat outside 24/7/365, which means it sat outside too. Between 100 degree sunny days and -20F winter nights with 8 inches of snow piled on it, and when I moved it to my 2021 it still looked like new.
I ordered some replacement parts for it before moving it because it has foam pads in a few spots, like where it would rest against the window if folded all the way up, and those were starting to come off at the edges (just on with adhesive). So $15 in some refreshed wear and tear items and it just keeps on going.
