Lightning Snow Plow?
BobKenyon
Bob
Hopefully a Lightning
Has anyone used their lightning to plow snow? Apparently Kansas lacks passion about removing snow on side roads...
tls
New York
2022 Lightning
The suspension isn't really built for it. One of the big differences between a Super Duty and an F150 in general - the front is built to take the impact from slamming the plow into wet snow, or whatever's under it. It's possible, but it's not a great idea.
Dglambert
Devin
2024 F150 lightning Lariet ER
Software engineer
True, but my fixation is currently on the lighting, unfortunately for better or worse. Then again I've got an 85 350 diesel crew cab with a flatbed in my backyard (and a plow! And another engine for rebuild) that hasn't gotten any love in almost 10 years, and i have a feeling that project isn't gonna be cheaper either! I need another truck! One new, one classic, and one beater!!
RickKeen
Rick
F150L SR Pro
sw engineering manager,
Its also about the front suspension having enough capacity in the front axle just to carry the plow. You can easily overload your front axle and tires. The Lightning is only rated to carry 400 lbs directly over the front axle in the frunk. The Lightning's front tires and axle are not going to do well with a big 1000 lb 9' hydraulic angling v-blade. Also there are the dynamic loads of the the plow hanging 5' out in front of the truck bouncing up and down on every winter pot hole.
You would want the smallest, lightweight plow you can find to bolt on a Lightning. Might be good for personal use on one driveway, but if you intend to plow all day, all winter, you are going to need a much heavier duty truck.
GarageMahal
JT
Data Wrangler
Agree that any plow needs to light weight and I wouldn't do commercial use. Hoping to put a homeplow on someday...
zinkscott
Christian
2023 F-150 Lightning Platinum
Cloud Engineer
I’ve seen another individual follow CyberBill. He’s active on Reddit.
It’s not just side roads. Kansas doesn’t clear the roads at all.
Dglambert
Devin
Software engineer
Thanks Rick, these are good points i hadn't considered. Curious how this compares to ICE f150s and F250/350s? Im not familiar with the 400lb rating, do you have more info on what the actual measurement is called?
RickKeen
Rick
F150L SR Pro
FYI, google says an F150 ICE with the plow prep package is rated for light duty plows up to 450 lbs. An F250 with the plow package up to 1400 lbs.
The Frunk capacity is mentioned in various Ford literature:
https://www.fordpro.com/en-us/fleet... up, and can hold up to 400 lbs.,-As its name
jeff_h
WV
2023 F-150 Lightning XLT ER
Paint-Drying Observer
Here's a recent reddit thread on that very topic, where owner from VT has one installed:
SpaceEVDriver
Arizona
I attached my plow to the rear hitch. It works great.
Ford F-150 Lightning Lightning Snow Plow? PXL_20250314_154601781.RAW-01.COVER~2
Ford F-150 Lightning Lightning Snow Plow? PXL_20250314_155039492.RAW-01.COVER
Ford F-150 Lightning Lightning Snow Plow? PXL_20250314_154623476.RAW-01.COVER
