Second opinion on spray on bed liner from factory
My brother got this truck on Friday and noticed some of the bed liner starting to peel next to the cab. When he told the dealer that he bought it from (out of state) they said, "well we sent you a video, so not our problem". I get that there's nothing they can do being out of state, but what a crappy response. I told him to contact a local dealer as it should be a warranty fix. Was curious what y'all think. Including driver side (has peeling) and passenger (no peeling).
Ford F-150 Lightning Second opinion on spray on bed liner from factory 1000007352
Ford F-150 Lightning Second opinion on spray on bed liner from factory 1000007353
The Weatherman
Dean
South Central KY
To honest, where it’s located I would likely smooth that out with a light sandpaper and let it go. If it continues to peel up, then I’ld fight with dealer for some help.
But that’s just me. You do you.
I'm completely ignorant when it comes to bed liners. His concern is that it would continue to peel off.
The Weatherman
Dean
South Central KY
It’s hard to know if will continue. That depends on preparation and what caused it to start with. That said I have 20 year hold Kubota side by side that had a small chip occur shortly after spraying the dump bed and it has never gotten any bigger.
3rdgenfan
Geoff
Delaware
Cybersecurity
Bedliner is covered under the 3yr/36k right? I'd just go to any Ford dealer. Doesn't appear to be a "tough bed" if it's peeling up at the edges.
Randall Stephens
Seattle
2023 F150 Lightning Lariat ER
Jet Builder
Dealers suck. That said, I’d expect a tiny bit of peel here and there. I just removed a few little spots on mine and went on with life. If it’s actually peeling more than just a small thin piece around the edges then I’d say something. I’d watch it for a while and see what it does, personally.
gbuydos
Central Iowa
F150 Lightening Flash '24
Well its a two edge sword. I opted for a aftermarket vs dealer. However, my Pro-power went on fritz, they left a connector loose and my back up sensors are wonky. If the dealer installed, most likely would not have the other issues but a cheaper bedliner??
It's sprayed at the factory.
No, it's a dealer sold and installed item. Probably little to no warranty.
It's also a bed liner and the top section they put it on is difficult to prep and evenly coat so it doesn't peel.
Webbo85
Marc
Glenmoore, PA
2023 F150 Lightning Lariat ER, 2023 Mach-e, 2002 Jeep Wrangler
Mech Engineer
If you select it when you order the truck, it's done at the factory.
I have the optioned bed liner on mine and it looks smooth all the way across. It's listed on the window sticker, so it better be covered 3yr/36k. I Ike the idea of sanding it smooth there. Seems like that ought to prevent it from continuing to peel.
BennyTheBeaver
The Window Sticker also can confirm that information.
Nikos
Nicholas
Taylors SC
F 150 Lightning
Aircraft Mechanic
This is a factory job. Ford did it at the factory. Ford will and should fix it for you. You file it thru them, (Ford). They will direct you to your dealer or an approved shop for another coating.
Have Ford involved in this and Ford will tell your dealer what to do in a very direct way.
Ford, also will ask you if you received the service you expected and if not you can give your dealer a nasty review thru Ford. Expect a phone call from your dealer to make sure you get your issue fixed. There is no such a thing as being out of state vehicle or a job.
The truck is made in Michigan, surely is made out of state for the majority of us.
Ford doesn't apply the "factory" bed liner at the factory. They are done at a supplier park by a vendor about a mile or so from the Rouge site. They fall under the 3/36 warranty.
He's also got a fast blinker/blind spot system warning that he needs to take it in for. I told him to have the peeling looked at as well. The dealer he bought it from is communicative, but has provided zero help since it was picked up for transportation. Will post an update when he gets it looked at. Thanks all!
