Working Pro Power using Generator Lockout Kit to Feed the Whole Panel
The neutral is connected, the ground from the main panel is not. All current on the hot legs is returning to the earth via the main panel
Current does not “return to earth.”
Danface
Danface
Dan
Central Mass
2023 Lightning XLT
I posted the drawing in post #101 to show the shock hazard should the neutral connection become disconnected (failed) from an ungrounded power source.
The attached photo shows an L14-30 plug which went open due to rough handling. Although this failure was on a line connection, the open circuit could have just as easily been on the neutral pin. Prior work experience, and this failure prompted my "Show some love to your L-14 Plugs" post on this forum.
Steve
100% agree. I mis-spoke, I said Nuetral but mean Ground. Inspector is coming this morning!
Danface
Danface
Dan
Central Mass
2023 Lightning XLT
I'm not not home but the inspector came and I don' think he even looked at the charge setup so "all good"
FloridaMan655321
Banned
Banned
Banned
1973 F100, 2024 Flash
Wherever it goes, it uses the neutral to get there :)
This is my thought, which leads me to believe it's a very very extreme circumstance where you would actually get shocked. Almost like you would need to design a way or create a physical cut into the wire. Again, I'm dumb, so.....
Danface
Danface
Dan
Central Mass
2023 Lightning XLT
The truck has GFCI built in and the metal body and cover of the generator plug is connected to it so that would trip if that grounded out (covered with snow or something metal leaning against it) and that seems like it would be all that's needed since it would only have current to it when plugged into the truck. Now if I ever used a non GFCI generator the yes, attach the ground from the house to the generator plug box.
drewfaulk
Atlanta
2022 F-150 Lightning
Long story short (pun intended), the GFCI on the truck will trip off if the receptical ground wire is connected to the ground wire coming from the panel. So run all 4 wires from the panel to the generator plug and don't connect the green and connect the green from the truck side of the plug to the front of the plug and to the receptical hosing.
Because the generator (truck) is not connected permanently (ie for emegency use), it's legal (in a lot of states) for the ground to float.
One NOTE, I have one more thing to do before we call the inspector but the work was done with a permit and by a licensed electrician.
Quick question about this. Couldn't you add an additional layer of safety by capping the "ground from truck" and tying the "ground from panel" to the point where you had the truck grounded (please see below picture for reference)? It would seem that if one of the hots came out of the back of your inlet and touched the box that it would be more likely to trip the breaker, rather than energize the metal box, if the box was tied to the incoming ground (in the event someone steps on/pulls the cord, bumps the box with the car, lawnmower, hand truck, etc., uses the inlet box as a step to reach something overhead....). I imagine there's a chance the truck wouldn't like this, but it seems like I've read about people modifying cords to not have a ground, so I'd think this would work. It's always possible I'm just wrong and this doesn't do anything safety-wise....
Proposed Modification:
Ford F-150 Lightning Working Pro Power using Generator Lockout Kit to Feed the Whole Panel IMG_20240925_080549.MEDIUM
It really doesn’t matter. If a live wire were to contact the box, the GFCI will trip. It will never be energized.
drewfaulk
Atlanta
That makes sense. I guess, unlike an outlet, an inlet is not energized when not in use, and, because of the interlock, would never be receiving power from the utility.
Danface
Danface
Dan
Central Mass
2023 Lightning XLT
That crossed my mind too and, as mentioned above, the box is GFCI protected by the truck when enegized so "toss a coin" so to speak. I guess if a circuit was leaking current to ground and/or the panel ground had a high impedence for some reason then having the panel ground isolated could prevent the input plug body from being hot maybe??
drewfaulk
Atlanta
That might be one scenario where it could make a difference, but more likely I’m just inventing things to worry about.
Danface
Danface
Dan
Central Mass
2023 Lightning XLT
Too much to know, too little time to learn it and too much information and misinformation available = too much to worry about. :)
drewfaulk
Atlanta
Does anyone know why I couldn't have interlocks on both of my adjacent panels, with a 30A breaker being fed by the the generator inlet on one (like Dan's setup), and another 30A breaker coming back out (with a handle tie to the interlocked breaker) and feeding a third 30A breaker in the 2-4 position (also interlocked) in the second panel? I borrowed Dan's photo and duplicated it to show the two panels and proposed configuration. I've seen a lot of online discussion about this, and it usually revolves around using a splitter and two inlets or a junction box. I understand I couldn't run everything on both panels at the same time, but the circuits we would want to energize in an outage are spread just evenly enough between the panels that it would be a nightmare to try to rearrange, and it would mess up the load balance, I would think. Any thoughts on this setup?
Ford F-150 Lightning Working Pro Power using Generator Lockout Kit to Feed the Whole Panel Screenshot 2026-02-07 at 12.37.12 PM
Danface
Danface
Dan
Central Mass
2023 Lightning XLT
What is the intended use for this setup? The single most important thing is to prevent power going to the generator while the main is connected/hot/"on" and vice versa.
