Without power for the day
FloridaMan655321
1973 F100, 2024 Flash
Getting a new panel installed, along with a generator outlet on the side of the house, and Level 2 charger. So today I'll be without power most of the day. Ran some extension cords for more than I need and it is kind of impressive how little power things need. I ended connecting more...just because.
Chest freezer, fridge in the garage, keezer (chest freezer for beer), internet and server equipment, office computer with multiple monitors, along with some security cameras. Also, it's very nice having wifi AP's that are PoE (power over ethernet) so wifi coverage is still awesome. Anyways, as you can see, barely using any power.
I might connect my well pump just because haha.
It's going to be very nice finally getting L2 charger installed and have an easy way to connect the truck to power on certain parts of the house. I'm thinking I can run my hot water heat and well pump at different times and still be able to run the rest of my house (without AC or oven or washer/dryer of course). Kind of exciting to have this setup.
Ford F-150 Lightning Without power for the day IMG_0564
mb0220
Matt
2022 Lariat ER
Ummm, what is that toggle at the bottom? Keep outlets on when vehicle is off?? I thought this wasn't possible. Is that a recent update?
mrau
23 Lariat⚡ER
Believe "Keep On" toggle is a 2024 option.
Wonder if @bmwhitetx has found a FORSCAN change that could add that to 2022/2023 models ?
FloridaMan655321
FloridaMan655321
Hmm….. I need to test this. I just kept turning the truck on and enabling the rear and disabled the auto shutdown. I didn’t even notice this option (or if it’s new from an update)
mrau
23 Lariat⚡ER
@FloridaMan655321, if you get a chance push the little _i_ button next to the Keep On toggle and let us know what it says.
I have walk away lock on my 2022, but I did just get a module update at the dealer recently.
Correct. Many 22-23's got it because the dealer updated the BCM. But they likely didn't enable the Sync setting to turn it on/off or disable the horn honk. So you probably don't have the settings outlined below.
Ford F-150 Lightning Without power for the day 1739919120506-gq
HOTAS
Airbus Pilot
Remember, you don’t even have to go inside the truck to power on the ProPower outlets.
Just unlock the truck with the remote or touch door handle, and power on with the panel in the bed. That will also power on the cab outlets too.
Many folks don’t realize they Don’t have to get in the truck, power up, mess with the screen etc…
