Dinozero
Kentucky
2023 F150 Lightning ER Lariat
Many people on the F150 forum are reporting getting the OTA and it fails. When I check the VIN, the reason on three trucks today alone were "canceled by the cloud" which means the OTA trigger was canceled on the server side. No reason as to why the OTA was canceled is given.
Ugh we all hate to hear that. Wonder if they found a dangerous bug or something bricking vehicles.
The OTA is failing time and time again on the F150 forum with server hash mismatch errors or just canceled by the server altogether. Something is up.
Mine failed too. It timed out on downloading and expired. Looking at the OTA dashboard, it's a IPMA and PSCM module update. My IPMA updated, but the PSCM did not. It says the OTA will retry.
Really? It shouldn't work like that. That's very strange. Any codes? Does lane change work?
Yes, but I had the front sensor CSP done and enabled it in FORSCAN.
My OTA started on January 10th. Under the Vehicle Software tab in PTS, my BCMC and IPMA modules were updated on January 11th. It showed that I had an update downloading until February 10th, and now shows it's expired and will retry. According to the OTA Update Dashboard, the IPMA and PSCM were the modules that were supposed to be updated.
digitaldad
ABQ
2023 Lariat ER MaxTow
I have now updated via FORScan and FDRS but yet to get an OTA update...granted, I've only had this 2nd hand truck a month. But I would still like to see one succeed.
Today was the first time I used the auto-lane change with BC, and it did it very confidently. I also noticed the lane positioning working via a semi coming up from my rear driver-side, I guess I assumed that only worked when I was passing large vehicles.
Ekiehn
Eric
2023 F-150 Lightning Latiat, 2008 Ford Explorer, 2006 Ford Escape Hybrid
I would be curious if this latest round of 1.4 updates have the same release note that Sync updates are coming later. I.e., you don’t have the toggles for Lane Change Assist and In-Lane Repositioning (but the functionality is there).
Yes that was what I saw in the release notes... Still noting the toggles will be coming... didn't look yet to see if they might be there.
Ekiehn
Eric
Here are what the original notes said (post #11):
I also got the early update but I had enabled sliders with FORScan. That’s why I’m curious if this update has notes that said the same thing.
Also curious if the update release at the bottom is still IPMA-24.204.10.9
My recent update states IPMA-24.204.10.9 so it looks like it is the same...
Fyatrk
Christopher
Tecumseh, ON
F-150 Lighting , Tesla Model Y
Just realized I got mine today. Tried it for the first time and it worked. It doesn’t really show much different on the display. It just works. You put the turn signal on and it changes the lane quite slick actually
Ekiehn
Eric
I tested it out yesterday and it worked as expected.. Nicely touched the signal and speed up and passed a semi... kept a nice space between it and my truck, then touched the signal as I was just past the trucks cab and It Nicely pulled in front of the semi with nice space... tried with some cars and all worked very well... Happy with it so far...
