Running the Battery to 0%
Box Cat
Portland, OR
That is interesting. Any other similar entries in the shop manual? Is the cell rebalancing timing conditions addressed?
The description is very terse. Instructions direct technicians to trigger a 48 h cycle at the end of which balancing is either done or interrupted, then scan the average voltage variation PID and repeat with extra cycles if needed. There is also another procedure applied at the large serviceable module level (not the cell groups) which uses an external tool for faster balancing when replacing a whole module. In the end the goal is the same, reach a balance on the open voltage of the individual cell groups (as an approximation of SoC balancing) which are the ones that are sampled by the BECM. I suppose this is possible over such a large voltage range since the slope is rather linear and not flat like in LFP cells.
Yellow Buddy
Smart Ass
That’s one status that was available in ForScan that wasn’t available in CarScanner (that I saw). There’s a sensor in the BECM that read the rebalancing.
flypony53
Rodney
Houston, TX
22 Ford F150 Lightning Platinum, 21 Tesla Model Y, 24 Tesla Model S
I had a similar experience, and while at first I thought I was 'out' of all power, it actually wanted me to put it in PARK, then back into gear, to move forward, even slowly... give it a try next time.
I tried this. When putting it in drive, I would push the accelerator and the truck would roll back slowly, so I ended up back in neutral pushing it...A heavy beast!!! I got my workout in for the 300yds back to my house...
KickingGas
Toby
Indiana
2023 Lightning Pro w/ Tow Tech Package
Just as a follow up to my earlier post (#4)... AHHHH... SUMMER!! This is me the past couple of days. I have a Pro. Check out my alleged 100% range. The other pic is my GOM at the airport, at 73% compared with 53% in winter at 40 degrees doing the exact same trip. I ran the A/C the whole way down too.
Ford F-150 Lightning Running the Battery to 0% 73 per
Ford F-150 Lightning Running the Battery to 0% 249 mi
MM in SouthTX
2025 Lariat PowerBoost with 7.2kW ProPower
I expect to get 600,000-1.5M miles from both the Lightning and the Mustang.
I wonder how far out Ford will support the software on the truck. With newer vehicles, will software support be akin to trying to find a window crank for a '72 Malibu?
SpaceEVDriver
Arizona
As long as Ford doesn't sabotage the software when they EOL the vehicle software support, I don't think it'll matter much if they provide ongoing OTA updates. And at some point we'll find independents can make updates...
MickeyAO
Mickey
San Antonio Tx
Did you decide to sell yours yet? Mine goes on the market the same day yours does.
You’re my canary.
The canary has left the coal mine and is joining you over at the KiaEVForums. Traded in for an EV9 GT-Line
MickeyAO
Mickey
San Antonio Tx
Yellow Buddy
Smart Ass
Can you point me to a better EV9 forum?
I haven’t been able to find one I like unfortunately. The layout over there isn’t wonderful, and the people are…interesting.
I pop in from time to time but haven’t really been active over there.
Are you now going to ruin the EV9 for me so I’ll have to sell that too?
@TaxmanHog
Can you just add a EV9 sub forums on here? A bunch of us from here have one now
MickeyAO
Mickey
San Antonio Tx
@TaxmanHog
I'm retired from the lab and I'm blissfully unaware of any problems with the cells. The best I can figure out is these are still CATL cells, which have been solid in previous testing I did, but the tabs were horrendous on one specific cell I tested...layered thin strips of aluminum that did not hold up well for a specific customer I was testing for.
Yellow Buddy
Smart Ass
Congratulations on your retirement!
CATL has been in the game for a while so hopefully it holds up. I’ve got more miles on my EV9 right now than my Lightning, and I just bought that last summer. It’s gone through a good amount of DC/AC cycles with no major signs of degradation or instability so far.
It’s had a lot of recalls but luckily my dealer has been good. The only thing that does concern me is the rear self leveling suspension. On curves where it’s bumpy, it loads up weird and can cause the rear end to skip
But otherwise we love the car. I’ll see you over there
MickeyAO
Mickey
San Antonio Tx
I don't have that level of power, but you are welcome to start new threads under this section.
Lightning vs.
I'm sure you know the people whom have that level of power...perhaps you can bring it up!
