lex
Jason
2022 F150 Lightning
It looks like your truck is a tad bit too long for that parking garage space. ?
Yup, my biggest issue with the truck by far. Too long and difficult to park.
mb0220
Matt
2022 Lariat ER
IMO yours is the best look of all mods I've seen. I too struggle with not wanting to risk the squatting look when carrying a load...
You mentioned that your battery SoC typically goes from 80% to 20% after 3 days. I'm wondering, is there a reason why you don't just plug in every night? If it's a parking/convenience issue then I understand, but its generally healthier for your battery to have short charges every day as compared to longer charges once or twice per week. It also eliminates the risk of being stuck with 40% when there's a sudden unexpected need for a longer drive.
Bokenator
Curtis
Georgia
2023 Lightning Lariat - Antimatter Blue. 2020 Hyundai Palisade Limited
I am heading down the same path as the original poster. I have installed the Eibachs to the same 2.1" on the front only. That change alone had no discernable impact on range, as my average was 2.3 miles/kW on stock, and remained 2.3 miles/kW after the lift. I drove 20k+ miles stock, 9k+ miles with the lift alone.
The Eibach shocks fixed the floaty feel, and leave a slight rake. I would tell you my impression was that road trip highway range decreased slightly, but my daily commute is not enough highway driving to impact the total overall average.
Last week, I installed the Toyo Open Country EV in the same 275/65 R20 size as OP. As he stated, it is a slightly larger tire, as my OEM tire was the Hankook Dynopro (see comparison snippit below). I haven't had the truck recalibrated yet either, as Discount Tire doesn't perform that service.
Ford F-150 Lightning Eibach 2.1" level, 275/65R20 tires, Fuel Rebar +20 wheels Screenshot 2025-04-23 110340
In the above chart, you will see the Toyo listed twice. The middle one is the SL tire, while the bottom one is the LT tire. Both are the EV versions. Note the difference in weight as compared to OEM tire which is highlighted in yellow. Also note how much heavier the LT version is as compared to the SL version. I bought the lighter version with the same idea as the OP, which was to minimize negative range impact.
I plan to drive these for a bit, then change out the rims. I'll report back on miles/kW after running these new tires for a bit (and getting the speedometer corrected).
F150ROD
U.S. Navy Retired
If you raise it a bit more you should have no rubbing.
lex
Jason
2022 F150 Lightning
Interesting. I have heard/read the opposite with regard to short vs long charge cycles. However, it i just more convenient not to plug it in every night as well. I will have to look into battery life vs charging behavior.
jetfixr1
Manny
Atlanta
2023 F150 Lightning Lariat ER
Anyone have feedback regarding CV wear with the Eibach lift? I rarely tow or have anything in the bed so im not concerned about squatting. I love the leveled look this provides.
FordTough98198
Domenic
Seattle, WA
22 Lightning Platinum
Business Consultant
yes and no. It is the oem carbonized grey but put Xpel stealth satin wrap over it.
XPEL stealth for the win. So many comments on it. Nice looking rig, man!
Ford F-150 Lightning Eibach 2.1" level, 275/65R20 tires, Fuel Rebar +20 wheels IMG_1396
abcut973
Anthony
Denham Springs
Not hijacking the thread but your truck looks familiar. Didn't you have it for sale on autotrader at some point? I think I came across your ad while car hunting for mine...
FordTough98198
Domenic
Seattle, WA
Business Consultant
Yep, it is for sale. I had it for sale here, but took it down after a while of inactivity. Basically in no sort of rush. If it sells great, if not, I am happy with it. I get bored after a time and want new things. The crux of being single and having a little extra spending money. LOL. I don't drive a lot so whatever I end up with, doesn't get a ton of use.
chuck27p
Chuck
Orange County, CA
F150 Lightning Platinum Black
This is great, thanks. I'm really interested in your findings with range, as I'm considering the toyo ev tires too, in that size or 275/70r18.
Bokenator
Curtis
Georgia
So this is a small sample size, but 1100 miles in, I am getting the same 2.3 miles/kW that I always have.
What is worth noting however, is that I never recalibrated my speedometer, as it is only off by a couple of mph at 70 mph, so hasn't been worth the hassle/cost. Given the data in my snippit about revolutions per mile, then the tires are travelling about 3.61% further than the truck thinks they are, meaning 2.3 X 1.0361 = 2.38 miles/kW.
I wouldn't put too much faith in this back of napkin calculation that insinuates the mileage being better, as the difference is probably well within the error factor of the guess-o-meter rounding itself. But I am pretty sure the mileage isn't any worse. :) And the tires look better, complete changes the look of the truck in my mind.
chuck27p
Chuck
Orange County, CA
Awesome, thanks for the info! Can you share some pictures of the setup, would love to see the stance, tires, poke...
lex
Jason
2022 F150 Lightning
I would imagine minimal range loss (<5%) if you continued to leverage stock wheels/offset/height and just switch to the EV tuned Toyo's. Its the offset poke and ride height that additively impact range.
However, at some point, you have to ask yourself.... Is losing even 15% of range going to impact my daily routine? Am I traveling or planning to travel a distance where this loss prevents access to charging stations? If not, then the question becomes, does the looks and ride quality change improve my happiness driving the vehicle.
If no, then don't do it and enjoy what you have. If yes, pull the trigger and enjoy your new experience.
