Can FORScan turn on Slippery Mode and previous Drive Mode for pre-2025 Trucks?
Kansan
Wayne
2024 Flash
Civil Engineer
I saw a photo that shows that Slippery Mode has been added to the 2025 Lightnings, so I confirmed by downloading the owners manual. I see too that the previously selected Drive Mode will automatically be enabled for up to 4 hours after ignition off. I'd love to have both of these in my 2024 Flash and I'm wondering if it's possible to enable those items via FORScan. It would be even better if we could change the amount of time that the previous Drive Mode would be active.
Ford F-150 Lightning Can FORScan turn on Slippery Mode and previous Drive Mode for pre-2025 Trucks? 1745922442161-2r
Ford F-150 Lightning Can FORScan turn on Slippery Mode and previous Drive Mode for pre-2025 Trucks? 1745922732306-k5
Jesse-Infotainment
2024 F150 Lightning Platinum
You can try. THe 25 runs a new ABS module. I had already looked into this when I saw the slippery mode in 25s.
The modes are activated int he ABS> THe 25 runs a new firmware and runs a new Expedition ABS module versus the F150 ABS
The change that would be made int he ABS module is
760-04-03XXXXXXXX6Xxx
The 25s run a new PCM firmware also. Cant promise this will enable the mode but this is what you would change to try.
Vypurr
24' Flash
This does not answer your question, but I have found that 1-pedal driving is an excellent replacement for slippery mode. The way the throttle and regen braking work do a great job of keeping the truck in a straight line in less than optimal conditions. After driving my truck through 1 northeast winter, I believe I would stay in 1-pedal in those conditions and not even look at slippery mode.
SpaceEVDriver
Arizona
If it would let me I’d put the truck into “slippery mode” when in cruise control on the freeway. I think it’s far too aggressive in its push to return to the set cruise control speed with its default settings.
Jesse-Infotainment
Kansan
Wayne
2024 Flash
Civil Engineer
Interesting - Livinitup's spreadsheet ends at 760-04-02, or at least the one I can find ends there. The As Built on my 2024 Flash includes 760-04-03 through 760-04-06. Is there a spreadsheet somewhere that defines those lines?
Most recommend NOT using 1 pedal in winter conditions, and driving in normal model.
Jesse-Infotainment
We have access others dont.
Livinitup only shares what he wants to share. Plus sheets can change as new info comes available and we dont update the sheets all the time because its not anything people need or care about.
Kansan
Wayne
2024 Flash
Civil Engineer
I made the change with FORScan. I didn’t get the desired result - Slippery Mode didn’t appear as a choice. Is there anything else I need to do with the change for it to be effective - reset/calibrate, etc.? Or is it just a no-go with the 2024 ABS module? (I updated all modules with FDRS a while back and there are no updates available, so I’m running the latest available 2024 PCM software.)
Jesse-Infotainment
If it didnt populate then it isnt there.
If the ABS change was made and didnt show then the ABS module is not programmed for it. These are different abs modules that what the 25 Lightnings have.
jetfixr1
Anthony
Atlanta
2023 F150 Lightning Lariat ER
Yea, hard pass driving 1PD in slippery conditions. The one thing they tell you not to do when sliding is stomp on the brake and letting go of the gas pedal achieves exactly this. I go as far as turning off 1PD during heavy rain incase I encounter hydroplaning.
GoodSam
Good
occupying space
Would not the anti-lock braking function take care of any excessive braking going on by regeneration? What other automatic steering & braking functions might help in poor traction situations? Is going slow and leaving plenty of car lengths the only options?
Yes.
AdvanceTrac electronic stability control limits torque in slippery driving conditions. With 775 lb-ft it probably limits torque in non-slippery conditions. It's seemless and you have no idea it's doing anything unless you hold your traction control button for 10 seconds to turn it off.
Slow and smooth is your best option in ANY vehicle. No software can defeat physics.
jetfixr1
Anthony
Atlanta
Yes.
Well stated
Lightning Bronson
Jansen
Greater Toronto Area
Snow Removal, Landscaping
I'd love a custom driving mode or something...
I want to be able to customize how gradual acceleration is, how aggressive is, and how stiff the steering wheel turns.
...I want the steering wheel of Normal mode, the Regen of Sport mode and the acceleration of Slippery mode ?
