luebri
Neenah, WI
I guess I'm glad I didn't push for this one last week.
I asked for them to look into it (while in for Light bar replacement #3) and the result I got was it did not get updated and they reset my Sync Software completely. ?
"Diag vehicle for issues with car play not working. Went to TSB 25-2048 but does not apply due to no software update available for the APiM and various other modules needed. Ran a software reset on the APIM and tested to see if carplay would work after. Carplay worked successfully in vehicle, customer will have to reconnect phone to vehicle"
Nolander
Scott
I took my truck in specifically for this TSB. The service advisor told me they would look to update all modules available and would look into this TSB. But, sadly after they had it over a week, I am now far worse than I was before. Prior, I had this issue about the same number of times, 1 out of 5 starts. Since my last set of updates from the dealer, I am up to 7 out of 10 starts without audio. So, not only did it not fix it, the updates made the issue far worse.
It seems to have resolved itself since I last posted. If I had to guess it was the iOS level I was at.
flypony53
Rodney
Houston, TX
Ford F150 Lightning, Tesla Model Y, Tesla Model S
I am working directly with the service guy. We are going to attempt to recreate it with a service tech, but it is so hit and miss, more hit now than miss. Yesterday 3 of 4 drives had the issue. I have a quick reconnect pattern now that it is more of an inconvenience than anything. I disable wifi then bluetooth and reenable both and connect manually. This works every time, but still annoying. I have never had this issue on any other vehicle before. Not sure why @Ford Motor Company has such a problem.
And, now going on 9 months with no OTA, no issue, no updates in queue according to service team. I wish Ford would go to release revisions like Tesla, Lucid, Rivian, etc. Let us know what version we are on. Communication is key to any good relationship. :)
Nolander
Scott
I find doing a system reboot simpler to resolve the issue.
Sadly the simplest and most reliable is just to plug in each time, but yes, I know, we shouldn't have to. We know that Ford can't do SW though, so I just try to accept this one and plug in.
tearitupsports
Russell
Houston, TX
If you go into the vehicle menus and go to phone list, just turning off and back on the icon for CarPlay will re-connect and fix the audio. I think that is quicker than resetting the whole sync system.
I was having occasional Sync freeze-ups (very infrequent). I mentioned this to the dealer when my truck went in for the 10K service and they applied this TSB. So far, no issues. Plus, I now have the latest interface.
Pottsie
Huntersville, NC
2023 F150 Lightning Platinum ER & 2006 F150 XLT with 275k miles on it
Not necessarily. Used to work for some of us. But not now.
dovetaildan
2022 F150 Lightning
Was in the dealership for an inspection and what do you know. They agreed to apply this update for me. So far so good… :)
Do you know what updates you got out of it? Did you get the recent BCM update or did they do that locally?
GoodSam
Good
occupying space
It seems my dealer updated all modules when I took it in for the CSP 24B56 front sensors and CSP 23B50 Charge Port Temp. I thought that doing all the modules for 25-2048 (or now 25-2105? also was SSM 52574) would take several hours, which was not shown on the service sheet. Confirmed by dealer and @Jesse-Infotainment .
Same here. I now have the latest BC, walkaway locks, and who knows what else?
Your Sync version should now be 25094 if the APIM was also updated.
