VoodooV4
Cape Cod MA
2023 Lariat ER - CGM
ER RN
The harness is definitely won’t plug-in. They are entirely different. The part number above use is a four pin harness. The Ford lightning at least for the 2023 model has a six pin harness which also incorporates the side crash sensor.
I was installing a sound system, so I haven’t had a chance to mess with the other lighting, but I can also verify the same for the front doors as well as the rear.
Interesting, it may be that the ICE trucks are different - so may also not applicable to 2022's. I'll update post 1. Sorry about that.
VoodooV4
Cape Cod MA
ER RN
@VoodooV4 were you ever able to figure out a way to use your assembly?
Sorry for the late reply.
Not yet to be honest. I was installing a sound system when attempting the doors so I figured i would get it done at the same time. I plan to revisit this at some point. Not only are the electrical connections different, but also the mounting points for the ambient light attachment screw holes are in different spots. Im most likely going to need to design something on my CAD program and 3d print. Will update within the next few months. Project is definitely doable.
derelict
XLT ER
Good info, thanks. I was about to go down the same path, I am thinking of upgrading my speakers and thought this would be a good opportunity to add in the ambient lighting since it was plug and play for the ICE Gen 14. I'm thinking maybe I should still just buy them and macgyver something...
mikefromchi
mike
chicago
2025 Ford lightning Lariat
Has anyone attempted this since the last post? I’m considering adding it to my ‘25 Lariat if it’s not recreating the wheel per se
