Fog lights and ditch lights with backlighting, switches, and canbus integrated controls
Runaway Tractor
Runaway Tractor
Yes
I'm sure there are canbus lines with the needed signal under the hood but not documented so IDK where. There are other CanM8 devices that include more/other light signals. I wanted the side lights since that drives the amber backlighting of the LED pods.
Telemachus
Lightning
I don't know that that's a lot of help for lights up front... But thank you for the link.
bordner42
Brendan
F-150 Lightning Pro
I assume he ran the front fender flare lights to the back too, but trying to get a follow up from him. Either way, running a wire slightly further to the tow hitch seems like it could be easier than canbus for something simple like DRLs.
Telemachus
Lightning
The wire from that trailer hitch has to make it up to the ECU. There's got to be a spot to tap it somewhere along the way without having to go all the way back to the trailer hitch.
In my case I am just putting DRLs up front and lighted emblem.
bordner42
Brendan
F-150 Lightning Pro
I don't disagree, but this is the first I've seen someone be able to tap into the DRL from the truck without the canbus. If you find somewhere else better, let me know!
Telemachus
Lightning
Despite other sources that I have read that say you cannot tap into the headlights, this guy seems to show that you can.
cliffmoon
Cliff
puget sound
F-150 Lightning (on order)
Wanted to pick this thread back up. Looking to power some accessories off of the parking lights, etc. But canm8 is no longer answering emails. Trying to get something up and running using an ESP32 with a CAN shield. I can read from the main HS-CAN lines but no codes are getting broadcast on the MS-CAN network. All documentation I can find seem to indicate that lighting codes get broadcast from the MS-CAN.
@Runaway Tractor what lines did you tap in the footwell for the canM8?
Telemachus
Lightning
Where are you reading the CAN bus from? Are you using SavvyCan?
Telemachus
Lightning
It's a grey/something pair in the left footwell driver side. I wish I took my own picture of it. I'm trying to find the picture I found online somewhere of it.
Each can bus will have its own twisted pair.
Are you looking at two different twisted pairs of wires?
How did you tap the wires and what are you reading it with?
MS-CAN is a slower protocol than HS can
cliffmoon
Cliff
puget sound
So far I've tried to tap at the OBD-II port, which from the documentation I've found has an HS-CAN pair and an MS-CAN pair. Using an ESP32 with the mrdiy CAN shield and writing message hex out to my phone via bluetooth. I can read messages from the HS-CAN, but it's simply spamming message ID 0x59E. Not able to read anything from the MS-CAN. Shield is set to read only mode simply for sniffing currently. Have configured the code sketch for the correct timings (500kbps for HS, 129kbs for MS)
Runaway Tractor
Runaway Tractor
Yes
The CanM8 device is what reads it. I tapped into the grey canbus pair there by the door at an existing molded connector, and ran my own twisted pair to the CanM8 unit. I believe the grey pairs are MS-CAN.
