- First Name
- Greg
- Feb 15, 2022
- Dallas, TX
- Lightning Lariat ER, Performance Y
- Occupation
- IT
I may have gotten that confused with this one. I rarely use the Pro Power and we've been through a couple of iterations, I don't see that we've discovered how on the older trucks - at least we can default the state of it however so it doesn't shut down on you if you forget to check it. Sorry about that.Which mod give the Pro Power On with the truck off? I was trying to look for it but can't find it.
This is what I was thinking of:
Disable Vehicle Power Down Timer at Start - Whenever you start your truck, the Vehicle Power Down Timer is always enabled. This shuts the truck off after 30 minutes. This mod defaults the timer to off at start. See this post for details, warnings and source.
IPC 720-01-01 x*xx xxxx xx if F then change to 7, if C change to 4.
Note that 2022-2024 Lightnings with ACC will have a "F" and trucks without ACC will have a "C". As always, let me know if you see something different.
