F150 Lightning FORScan thread - Version 2
Has anyone verified if easy mode increments the bits set amounts, or if the just change the bit to a set value?
I suppose it could be either
The one time I compared, it flipped the bit correctly. But that's just one check.
I agree with @rugedraw - you are at the mercy of the FS guys. They are a bright bunch no doubt, but I'm also in the "show me" camp.
@bmwhitetx - on the front page, the link "As-built Method" under the " Change Tire Size for Speedometer Calibration" section seems to have been deleted from the forums, FYI.
I used the spreadsheet from this link to get my values - Spreadsheet-Calculator
Thanks for the heads up. I have rewritten that mod based on your experience.
VAL.ABAPO
2025 F150 FLASH LIGHTNING 131kwh ER
thanks to these wonderful thread, i was now able to:
- fix the disappearing 24hr hour format.
i also did
-Change Number of Blinks for Turn Signal Tap
and
-Glare-free headlights
with the Glare-free headlights mod, shouldn't i be seeing a Sync UI change? I do not see any on mine.
VAL.ABAPO
Yup that where i saw it from.
so i have my light at auto. But don’t see the Glare Free option.
I double checked and triple checked the values that i changed and it looked liked i followed what was posted in post #1.
VAL.ABAPO
The front page states that it may take a couple of restarts (I assume the modules)...does your Sync still show auto-brights then?
Just as i went out to the truck to check as i wasn’t sure if i had auto-brights, guess what i saw! Yipee.
i also noticed some brightness prompt popping up on the cluster console.
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 IMG_5964
VAL.ABAPO
Id like to have the front camera active while driving would this be the right Forscan changes to make?
Enable OffRoad (Rock Crawl, Mud/Ruts, and DeepSnow/Sand) Front Camera at Speed)
IPMA 706-02-02 xxxx xx03 xx--
TIA.
TIA.
No, I don't think so. Did you get that from the the spreadsheet on the 14th Gen forum? That's specific to ICE.
I haven't seen anyone confirm it with the codes they used. But @Gerstein1989 and @Riverant said they got it working.
Maybe start with this post and the next three:
https://www.f150lightningforum.com/...t-camera-view-while-driving.24794/post-497946
You likely need the APIM change where you flip the bit on the OVS parameter.
Also note the caveats here:
https://www.f150lightningforum.com/...ng-forscan-thread-version-2.23634/post-496211
BriyGuyUSA
Glyn
Atlanta, GA
2023 Lariat ER 511A Antimatter Blue
IT Stuff
I enabled Glare-free headlights, Silent Mode, Trailer Side View and 50/50 view in camera menu. Now my mirrors don't auto fold when I lock. Any ideas what I screwed up? I did take a backup all the modules before making any changes so I can easily restore.
Scorpio3d
SS/IBA car wash owner
First, I would check the setting in the menu to make sure it did not change!
TanThePanMan
Tan
23 F150 Lightning XLT
Thanks for the help! Got glare free head lights and all the other changes working, however had one issue:
I already had WAL on my 23 XLT, dealer must have done the update as I bought it used, however didn't have the toggle so was attempting to add the walk away lock toggle and now it won't allow me to re-enable it. Getting "This setting isn't avalible right now" when attempting to toggle it back on. Does anyone have any suggestions?
Scorpio3d
What did you change?
