Center console rattle
C6Bill
C6Bill
2025 F-!50 Lightning 1970 Olds 442
If installing the safe requires cutting a hole in the bottom i might just put one in as an excuse to see inside lol
C6Bill
C6Bill
Found the video, i'll probably start taking pieces off until i can find it lol
digitaldad
ABQ
2023 Lariat ER MaxTow
Oh my, I've not seen that much work for this on the other threads/posts. Most just place them under the front spring tabs only (nothing to take apart).
Ford F-150 Lightning Center console rattle console_lid
C6Bill
C6Bill
I will probably throw some nickels in there first, see if that helps. But the rest of my day is dedicated to the 442, have a small oil leak so changing the valve cover gaskets. It's one of those old school vehicles that make a lot of noise lol
Ford F-150 Lightning Center console rattle IMG_1538
Harman023
Keith
Jacksonville,Florida
2023 Lightning Platinum
retired HVAC mechanic
I had a rattle that sounded like it was coming from the passenger side. My wife said it sounded like it came from the driver's side. After messing with stuff for a week, I opened and closed the moonroof. The noise disappeared. This has happened twice now. It was the first thing I tried when the rattle came back. I must be bumping the switch when turning on lights or opening the shade.
The Weatherman
Dean
South Central KY
I don’t think those springs are visible without taking a piece of trim off the back panel to expose them. I haven’t looked in awhile so I could be wrong.
K6CCC
Glendora, Calif.
They are visible without removing anything. May be easier to get to with some removal, but should be able to do the 20 cent mod without removing anything. I have not done the mod yet, but it's on my ToDo list.
digitaldad
ABQ
These are in the front by just opening the console lid and looking up in (at). The video that was posted earlier was the first time I saw anyone accessing the rear side (back cupholders) to access the rear/other side of the spring.
C6Bill
C6Bill
I tried the roof trick, no luck for me.
OT Ducati
Richard
2023 Lightning, 2022 Mach E
I Do Things
Had a rattle similar wife thought it sounded like her cheap sunglasses in the catch all in front of the shifter. It seemed like it moved around to me, I cleaned everything loose out of truck still could hear it. Took it to dealer they took the console apart and found an extra bolt that did not have a home. I don't exactly know where it was.
C6Bill
C6Bill
I'm thinking i might eventually get to the same place. I'd just rather find it myself, i'm stubborn lol
OT Ducati
Richard
I Do Things
I just didn't want to or think I should have to take the console apart in a brand new truck.
We like our dealer and trust the service department.
C6Bill
C6Bill
I do not disagree, it is just kind of a crappy trip to my dealer. There are other closer but i've never dealt with them before.
The Weatherman
Dean
South Central KY
They are not visible in my 2022 Lariat without taking out at least one piece of trim.
Ford F-150 Lightning Center console rattle IMG_2314
digitaldad
ABQ
Hmm, our trim pieces look the same but your picture is taken slightly from above looking down. The hinge is on the top, right under the opening lid. Down, looking up in that hole/slit.
See video, if yours is there too :) - I haven't done my nickel trick yet but am overdue as my lid falls down regularly.
