richl025
- First Name
- Rich
- Aug 24, 2023
- Bozeman, MT
- F150 Lightning Lariat
I put the quotes in the title because of course, Ford has failed to deliver such a (seemingly) simple option.
I just got back from an overnight camping trip, and was shocked at how much juice I lost running only a small powered cooler.
Truck left "on", lights off, climate control off and center display set to "quiet mode." Temps were in the 40s-50s at night.
SOC went from 60% to 54% over about 18 hours - that's almost 8 kWh!!!
The entire time I was using the PPOB, there was a subtle whine / fan noise coming from the frunk area.
The cooler is, admittedly, old. It's a Coleman, probably about 10 years old, and it's designed to run off 12V - but it comes with a 120V adapter. There is no power info on the cooler itself, but the adaptor states its max input is 120V 1.4 amp
So if my math is right, even if the cooler were running at _max_ for the 18 hours, that would still only be ~ 3kWh - and given the outside temps, there is no way the cooler was running that much.
Does this power "waste" match what everyone else is experiencing? Could this just be horrible inefficiency from converting the 120V PPOB to the 12V the cooler needed? I wouldn't THINK so, given the max power input of the 12V converter, but I'm trying to think of all possibilities.
I did a little test last night of leaving the truck "on" overnight without a load on the PPOB, but of course the PPOB shut down (no load) and I forgot to turn off the truck's shutdown timer
