‼️ UPDATE FORD E-RAPTOR grille swap and install tutorial
Telemachus
Lightning
I bough one from AliExpress, arrived yesterday. Looks great. Hopefully I can install it sometime the next weeks. Oversizing the holes for the letters helped with alignment. Used an 9 mm drill bit.
My plan is to print a mount in iterations until it is right. And make a small as possible hole in the grill. And the seal around the camera with some black matte Tec7.
Iterations was my goal as well.
Then I figured I'd get the angle right with hot glue and backtrack from there.
Glue still holding strong, lol.
Next I have to align my light bar
Ford F-150 Lightning ‼️ UPDATE FORD E-RAPTOR grille swap and install tutorial 20250821_081007
Ford F-150 Lightning ‼️ UPDATE FORD E-RAPTOR grille swap and install tutorial 20250826_011615
hb.sagen
Henning
Norway
F150 Lightning 2023 Lariat
After 4-5 different versions of a 3D-printet mount I finally got something that I will try on the vehicle.
It replaces one of the hexagons, so easy enough to remove the backside of the correct one (when I figure out which). I belive the lower wall of the hexagon needs some trimming as well, if so, I will make a jig for that.
This is printed at the lowest quality as fast as possible, and not finished any way. Just prototyping.
Ford F-150 Lightning ‼️ UPDATE FORD E-RAPTOR grille swap and install tutorial IMG_0943
AZT9
AZT9
Peoria, AZ
Elegant solution!
bordner42
Brendan
F-150 Lightning Pro
Very interested in this when you make a final product!
Telemachus
Lightning
It's a very cool idea, but you are going to have to cut out the bottom of the hexagon that you remove, to get the angle of the camera similar to factory default
hb.sagen
Henning
Norway
I did mount the camera and grill today. And the bottom of the hexagon needs to be trimmed, and more than I thought.
Keeping the original angle of the camera, and cutting only one hexagon, will limit the viewing angle achievable because the body of the camera hits the grill itself. I will trim some more tomorrow and see if its acceptable.
AZT9
AZT9
Peoria, AZ
Thanks for the R&D!🤙🏼
Telemachus
Lightning
Been there, done that bro. I feel ya.
If only the camera shaft was about 1/2 inch longer.
hb.sagen
Henning
Norway
How are you guys wiring up the lights? I don’t want to cut a hole in my fuse box without knowing it will survive 10 years of water and salt.
Milling out a trench for the camera might get a better view. It will extend the camera 3-4 mm further out. But careful to not mill all the way through the grill.
Telemachus
Lightning
Ford F-150 Lightning ‼️ UPDATE FORD E-RAPTOR grille swap and install tutorial 20250816_185959
Ford F-150 Lightning ‼️ UPDATE FORD E-RAPTOR grille swap and install tutorial 20250816_190006
hb.sagen
Henning
Norway
I ended up pulling it through the firewall and using fuse 35 in the interior fuse box.
hb.sagen
Henning
Norway
That's a lot of work when you have a whole slew of fuses right there.
Yes, it was some work. But as long the vehicle is under warranty I would like to keep my fuse box waterproof and untouched.
The climate here results in the cars being soaked in water and salt from November through March.
Telemachus
Lightning
I made the hole just big enough for the wire. Then once inside the water channel of the fuse box, I had it turn the corner to enter though second wall at a different spot.
A dab of silicone could be added at both spots if you plan on driving underwater.
I certainly think that's the least of the worries as far as water getting in.
