Ajzride
Alan
Houston
Eng
If I install it without the coupler I can just clear the errors on startup? Once I get the coupler those errors will stop showing or will I need to use forescan to clear any DTCs and then it'll startup without issue? I've ran all the wires and powered the comma to confirm no issues with screen. If I can just clear the errors on startup and then not have to do anything once I get the coupler, I'll give it a run
Most people can just wait 60 seconds before they put the truck in gear, and the errors will clear. A few people have had their AC stop working without the coupler. Only way to know is if you try.
mmarchand
Matt
does the A/C issue resolve itself if you disconnect the comma and/or use the coupler?
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
If you have the AC issue, it will resolve with the coupler. It usually sticks around until cleared otherwise.
Some have reported issues on the 24 specifically when comma power is in use with the coupler. But no one has responded back after its (assumed) resolved.
mmarchand
Matt
up and running. Errors but no A/C issue. Now I need to install new software to get it working?
mmarchand
Matt
Sorry to keep posting but I got Blue Pilot 4.0 installed. Took it out for a calibration ride and test. Seems to be working but not the best accuracy. It seemed to way over correct on turns and then force me to take over. Maybe this is a settings issue? Are there any settings that I should change for better performance?
UncleTony
Tony
https://bluepilot.dev/2025/07/25/bluepilot-4-0-release/
Change your driving model and it should straighten most of it out.
kzoojason76
Jason
2024 F150 Lightning Flash
@mmarchand - Looks like we have the same weekend project going on!! I just spent a bunch of time getting the Q4 harness hooked up. Ouch that was tight.. and I have large hands (unlike POTUS!!!).
@UncleTony and @Ajzride - is there a good reference to all of the "common" setting changes that are recommended? I tried to follow Branden Flasch's video of his install, but couldn't catch all of the settings. It also looked like experimental mode as grayed out and couldn't be toggled on.
Thanks again for of the great work/help on this!
UncleTony
Tony
There was no option to change the driving model. It defaulted to Tomb Raider and there is no other options. I tried to refresh the model list and nothing happened.
You need to be in off road mode. Either toggle it on the first tab, or turn off the ignition.
mmarchand
Matt
Thank you!.
Thank you! Now I can turn off off road mode? Or is there a reason to leave that on?
UncleTony
Tony
Thank you!.
Its only there so you can change the settings with your ignition on. Turn it off for normal use.
