Where to buy spare tire and wheel
Highpi
Ken
Sacramento, Ca.
2025 Lightning Lariat, Iconic Silver
For those of you who didn’t get a spare, where did you pick one up?
Dealer, local tire shop?
And is it an 18” or will a 20” actually fit under there?
Wk217
SW Utah
2025 F150 Lightning Flash (Job1), 2022 Mustang Mach-E Premium 4x
I wound up finding an OEM 18" steel wheel from an Expedition with the Maxxis Bravo 771n in 265/70r18 116T on eBay. Tires have a date of 32nd week of 2024.
I looked on eBay, Facebook Marketplace, Craigslist, Nextdoor but couldn't find any Aluminum 18" or 20" OEM wheels with usable tires under $400 all in, or were listed as a set of 4, etc..
This will go with a set of spare tire cranks and a Tall Boy OffRoad Bottle Jack kit.
Highpi
Ken
Sacramento, Ca.
I didn't think about Facebook. I found a couple for about $120 that look pretty good.
Do you know if a 20" will fit under the truck? I think if you got the spare when you bought the truck, you get an 18", for some reason.
Highpi
Ken
Sacramento, Ca.
I just saw a thread on this forum where Old Aviator has a 22" spare under his Platinum, so a 20" should be fine.
21st Century Truck
Martin
A 20 inch wheel with a full-sized tire fits in my spare wheelwell. I know this because I replaced my OEM limited-use spare with a full-sized 20 inch wheel + tire.
BTW - I have my OEM spare wheel + tire listed for sale in the Marketplace section. It's been sitting in the shed since last Fall.
Old Aviator
Larry
WPB, FL
22 Lightning Platinum 06 Magnum SRT8 23 Ocean One
Consultant
A 22 Platinum wheel also fits. Been there done that!
BriyGuyUSA
Glyn
Atlanta, GA
2023 Lariat ER 511A Antimatter Blue
IT Stuff
So if you have to use your spare, you would be running three 20's and an 18? Is that not dangerous?
21st Century Truck
Martin
I do not think the bolded statement above is correct. The bolding is mine.
My 2023 spare is a 20 inch diameter, not-full-width limited-use tire. Its diameter matches the 20 inch OEM wheels' diameter.
BriyGuyUSA
Glyn
Atlanta, GA
IT Stuff
Ah ok - good to know. I did look under there at mine but really didn't pay much attention to the size. I assumed it would be the same diameter but would likely be the narrow space-saving ones.
21st Century Truck
Martin
I learned from some pretty wise folks on the Mach E Forum back when I had the Mustang Mach E, that (especially on the all-wheel-drive models), EVs pretty much must have spare wheels the same diameter as their normal OEM wheels, because the wheel half shafts go directly into the electric motor(s) and not into a limited-slip differential like on cars we all grew up with. And thus, one wheel with a diameter different from the other wheel's diameter will pretty much reduce the electric motor in between them to smoking trash within a few miles.
Hence, Ford's solution as a "full-diameter, not-full-width, limited use" spare wheel and tire for the Lightning, imho.
Over on the Mach E Forum, there were several of us who bought a full-size, half-width spare wheel from an outfit called Modern Spare precisely to prevent that scenario.
All the more reason I think to invest into a real matching fifth OEM wheel + tire as the spare. I already used my spare twice.
Highpi
Ken
Sacramento, Ca.
Well, I finally got around to getting a full size spare. I got the 20" wheel off of ebay and the tire from America's Tire.
I also bought the OEM jack. Between the 25% off and my points, it wasn't too bad.
Everything fits like a glove.
Ford F-150 Lightning Where to buy spare tire and wheel IMG_3838
21st Century Truck
Martin
Congrats. This all doesn't matter... until one day when it matters a whole lot ;-)
I already used my full 20 inch spare several times. Especially in Winter when it's easy to hit that ice-covered sharp-edged granite curb and cut thru the sidewall. Ask me how I know this?
Athrun88
Toronto, Ontario, Canada
Wholeheartedly agree. Never thought I needed TPMS or a spare tire until I hit a nail in the road with my 4yo in the back going 120km/h on the highway. Suddenly felt the truck handle differently, more drag on the driver-rear, and the TPMS go off indicating the same. Quickly pulled over on the side of the road, 30 mins later, back on the road. Sure beat having to wait for a tow truck or something for a few hours!
Highpi
Ken
Sacramento, Ca.
Yeah, it's like a fire extinguisher, off in the corner, just in case.
K6CCC
Glendora, Calif.
Fortunately my 24 came with a full size spare. In the first eight months of ownership, I have had three flats - two of which destroyed the tire :curse:
