NEW PRODUCT | Diode Dynamics HitchMount LED Pod Reverse Kit
Mike G
N. AL, USA
I wasn't aware that the issues with that thing ever got fixed. I stopped trying to use it on my Lightning a long time ago and just stuck it on the back of my old Expedition.
4x4TruckLEDs.com
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Drug Dealer of the LED World
They did fix it. There are different harnesses you use. When we sell a kit we ask what kind of vehicle it's going on so that you get the right harness
Runaway Tractor
Yes
No sorry it's not a turn signal. It's reverse only or you can get it with a brake option
I know, that's what I'm asking about. What I'm trying to ask is, if you put a turn signal on, does the DD light:
A) Do nothing because somehow it's only getting a brake signal?
B) Blink with one of the signals since it's tied to one of the two brake lights?
4x4TruckLEDs.com
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
No it doesn't do anything, these are not turn signals. It's a reverse kit (with an optional brake function). It has nothing to do with the turn signals actually. Sorry for the confusion.
Runaway Tractor
Yes
OK good. But I'm curious how they've managed to do that? There is no brake-only in the trailer light harness. And splicing into the left or right tail light is the same issue I think since brake and turn signals are combined.
4x4TruckLEDs.com
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
Sure there is. 7-pin trailers have reverse, brake, left turn, right turn.
Ford F-150 Lightning NEW PRODUCT | Diode Dynamics HitchMount LED Pod Reverse Kit 1707755230533
Runaway Tractor
Yes
Sure there is. 7-pin trailers have reverse, brake, left turn, right turn, running
That brake pin is for the trailer brake controller's output. The voltage will vary from 0-12 volts with the trailer brake controller's desired braking force. But I guess if DD is using a voltage boost converter or something to make use of less-than-12v, it would work as desired. Creative.
foxfire235
Steve
Roanoke, VA
2023 Lightning Lariat
Real estate
Anyone know if this kits is fully updated and functional now?
4x4TruckLEDs.com
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
foxfire235
Steve
Roanoke, VA
Real estate
Awesome! Is there a forum discount code?
4x4TruckLEDs.com
4x4TruckLEDs.com
Gold Sponsor
Adam
Lindenhurst, NY
No sorry. Diode Dynamics came down on dealers within the last year and they DO NOT allow us to sell below MSRP anymore. We cannot provide discount codes, sorry. But it's only $99.95 for the C1 and if you get the C1R we ship it free.
foxfire235
Steve
Roanoke, VA
Real estate
Thanks!
SteuLight
Todd
Auburn, AL
2023 F150 Lightning XLT 312A
There are some changes available in FORSCAN that make it so that using the turn signal when a trailer is attached activates the side mirror camera. See here, and here.
Does anyone know if installing this will make those cameras work without the trailer (with the appropriate FORSCAN changes, of course)?
21st Century Truck
Martin
I've had my Diode Dynamics hitch receiver light for a year now. Very happy with it.
The original harness DD sent, did cause a fault (no reverse light) in the truck's taillight the DD light wiring plugged into, but only when the trailer was hooked up electrically. Last Winter, DD sent an upgraded wiring harness for this hitch light, and the upgraded harness fixed everything.
The DD hitch light BTW gives a WAYYY BETTER flood light to the rear when backing up.
I switch the DD hitch light to my teardrop trailer's accessory hitch receiver when I tow the teardrop. I bought and ran a 9-foot extension cable from DD to do this. Now, when I tow, the DD hitch light goes on the trailer. When I uncouple the trailer, I switch the DD hitch light to the truck. Best of both worlds.
Note: I have the CR1 version. It has the red running light function, the bright red (and initial flash) brake light function, and a flood white reverse light function. This is a very nice, easy mod.
And YES all the camera functions work with this mod, even the FORScan-upgraded camera functions.
digitaldad
ABQ
2023 Lightning Lariat ER
Thanks for the info...sorry, need some clarity.
Without a trailer physically connected and this light plugged in:
(a) the turn-signal activated cameras mod via FORScan work?
(b) are you also in a constant tow/trailer mode?
