Problems with both brake lights
Since you have a Lariat, check for water in your light bar. I believe besides making the light bar act weird, it can also affect the regular brake lights.
Lots of posts “water in light bar” you can read to see if your issue is the same.
flyct
Jerry
South Florida
Blissfully Retired
Hi, has anybody had any trouble with their brake lights?
Here is my situation, about a month and a half ago o so my right side brake light started having problems, it would sometimes work and other time it didn't. Then about two weeks after that the left brake light started doing the same thing. I was gonna change the right one but since the left one also started to fail then I thought it could be an electrical issue since I think the probability of having two LED lights fail is low. Sometime one works and then the other but mostly both do not turn on. If I switch the light switch off and press the brake pedal they would quickly flash but do not stay on. If I keep pressing and releasing the brake pedal all of a sudden either one or both start working, always one start working first then the other but no necessarily the same one work first. But if I return the light switch to AUTO after a few more presses of the brake pedal they stop working, also one stops working before the other. Same thing happens if i press the emergency light switch.
I thought maybe it could be a ground cable issue but this would make both lights stop or start working at the same time since I think both use the same ground cable once the join in the plug near the spare tire. I did take out one of the lights and checked to see if 12v was getting there and it was. The failure is with the parking light, brake light and blinker since I think they all use the same LED board just different intensities. The reverse light and the radar are both working fine.
Im asking to see if anybody had or hear of this problem to see if Im missing something. The fix would be almost $4,000 so if I can save that money would be great! Also I'm open to more ideas to test.
I can take and send a video if necessary.
Thanks
ebay has what claims to be Lariat tail lights for $700
https://www.ebay.com/itm/236146582620
walanis
walanis
Allan
Costa Rica
2023 F150 Lightning Lariat ER
You've got wiring problems, most likely a connector is getting wet and corroded. Trace it back and check for resistance.
I checked what I could and it all seemed ok, I also checked the voltage and it was a 12.6v when the ignition is on and car off, and at around 13.4v when the car is on.
I had the light bar replaced a couple of weeks before the lights started to fail. The light bar did have water, could that have also messed up the brake lights?
Thanks for the link. I’ll check it out for the driver side light since I’m getting the left light today and install it later. Hopefully everything work out ok.
