Naveen
Naveen
Louisville, Kentucky
F150 Lightning 2023 XLT- 311A
Yep, that's the plan. I'll build a "middleman" cable with deutsch connectors on both sides to connect CCM short cable with IPMA Comma harness mod.
What about the ForScan codes, can I stick with those posted in the 1st page since mine is also a '22 XLT? Are they still good or someone found a change for better results?
Good Morning @glicenji
Can you elaborate more on this one => IPMA Comma harness mod ? Do you have any picture for this one ? Trying to understand how this connection works.
glicenji
Las Vegas, NV
Tesla 3
Hi Naveen,
So basically all you need is a harness sold by comma 3x. If you never heard of it, watch this video because that will be the next thing you would want to buy for your truck when you are done with this project.
And since you'll need that Ford Q4 cable when you go for Comma 3x, mind as well buy it now. It costs $90 and they ship from San Diego. I'm in Vegas so I got mine in 3 days. If you look at the pictures you can see that I prepared a deutsch connector that I'm about to attach it to this comma 3x harness. Then you plug this to c134 connector and the c134 from truck to this harness, keeping your truck wires intact.
Take a look at this page of our forum when they talk about it:
https://www.f150lightningforum.com/...to-2022-f-150-lightning-xlt.14870/post-470433
Ford F-150 Lightning DIY: Installing ACC (Adaptive Cruise Control) and LKA (Lane Keep Alert) to 2022 F-150 Lightning XLT IMG_8265
Ford F-150 Lightning DIY: Installing ACC (Adaptive Cruise Control) and LKA (Lane Keep Alert) to 2022 F-150 Lightning XLT IMG_8263
Naveen
Naveen
Hi Naveen,
Thank you very much for such a detailed explanation.
Naveen
Naveen
Good Morning ,
I was able to finally get this one going this weekend :). A ton of thanks and gratitude to this community for helping me on this one.
Ford F-150 Lightning DIY: Installing ACC (Adaptive Cruise Control) and LKA (Lane Keep Alert) to 2022 F-150 Lightning XLT 1762174153651-in
@ZSC100 kudos to you for publishing the whole process with minute details. I took the route of inserting required pins to C134 and then routing it to IPMA module on the driver side.
I used Poshi tap connectors to tap into IPMA side wires.
Here are few of the links which might help folks looking to do it..
Posi-Tap 20-22 ga. Mini - Pack of 6. The Best Line Tap You'll Ever Use! (Choose Your Gauge Size and Amount) (6, 20-22 Mini): Amazon.com: Industrial & Scientific
tesa 51036 High-Performance PET Cloth Automotive Wire Harness Tape, Black, 19mm x 25m, 1 Roll: Amazon.com: Industrial & Scientific
https://www.amazon.com/dp/B00ZATMMEI?ref=ppx_yo2ov_dt_b_fed_asin_title
TUOFENG 20awg Wire Flexible Stranded Wire,20 Gauge Wire Tinned Copper Silicone Rubber Insulated (6 Different Colored 23ft / 7m Each) 20awg Silicone Wires - Amazon.com
Pins
https://www.digikey.com/en/products/detail/molex/0194170028/3183227
C134 Pins (Courtesy @ZSC100 )
Ford F-150 Lightning DIY: Installing ACC (Adaptive Cruise Control) and LKA (Lane Keep Alert) to 2022 F-150 Lightning XLT 1762174711146-19
IPMA Module wiring ..
9 - Green, White (GN-WH)
18 - Gray (GY)
19 - Gray Blue (GY-BU)
20 -Brown Blue (BN-BU)
Ford F-150 Lightning DIY: Installing ACC (Adaptive Cruise Control) and LKA (Lane Keep Alert) to 2022 F-150 Lightning XLT 1762173948719-fn
FORSCAN Changes ( F150 Lightning 2023 XLT- 311A ) - File attached.
While working with FORSCAN please make sure to take backup of modules to which we are doing the changes.. that way it can be restored in case something goes wrong.
Few of things which i learned while going through this process..
1) Please read through this entire blog (Page 1 - Page 50) to gain understanding of what we are trying to do and various options we have to accomplish this task. I didnt read through entire blog hence it took me 3 iterations to get it done.
2) Make sure to check if you have required wires on IMPA , C265 and C134 side.
DriveSide ( IPMA ) - Connector - C242B
Ford F-150 Lightning DIY: Installing ACC (Adaptive Cruise Control) and LKA (Lane Keep Alert) to 2022 F-150 Lightning XLT 1762174412783-f7
C265
Ford F-150 Lightning DIY: Installing ACC (Adaptive Cruise Control) and LKA (Lane Keep Alert) to 2022 F-150 Lightning XLT 1762174433050-24
Ford F-150 Lightning DIY: Installing ACC (Adaptive Cruise Control) and LKA (Lane Keep Alert) to 2022 F-150 Lightning XLT 1762174449907-za
Happy to answer any questions ..
@ZSC100 Quick question - Im getting "Keep your hands on steering wheel" a lot :) . I saw you mentioned somewhere -> " false steering wheel torque signal spoofed onto the FD-CAN bus so I don't have to keep my hands on the wheel. "
Can you please break this down for me :).. Not able to fully understand this one. Appreciate your support on this one.
Thank you
Ford F-150 Lightning DIY: Installing ACC (Adaptive Cruise Control) and LKA (Lane Keep Alert) to 2022 F-150 Lightning XLT 1762173894474-v4
glicenji
Las Vegas, NV
Tesla 3
Good Morning ,
Pins
18 - Gray (GY)
C265
Thank you
Great work. Glad you did it. I have almost all the wires ready and now waiting on the CCM to arrive sometime this Wednesday. I'm planning to finish this project on the weekend.
Did you have a problem recognizing the CCM in ForScan?
Naveen
Naveen
I did FORSCAN updates in below format
SCCM (Not required since i haven't replaced steering wheel button until now)
ABS
IPC
BdyCM
IPMA
After this did the hard reset of truck (Disconnect ForScan cable, unplug from Truck, Cycle truck Off/On)
Plug cable back in and connect with FORSCAN. Dont load Saved profile, let is rescan everything and it should show new CCM module.
glicenji
Las Vegas, NV
Tesla 3
ABS
IPC
BdyCM
IPMA
Great, thank you my friend!
glicenji
Las Vegas, NV
Tesla 3
Connect to IPMA and take a screenshot of the following values
706-19-01 xxxx xxxx xx--
706-19-02 xxxx xxxx xx--
706-19-03 xxxx xxxx xx--
706-19-04 xxxx --
Connect to the CCM module and input those values into these spaces.
764-01-01 xxxx xxxx xx--
764-01-02 xxxx xxxx xx--
764-01-03 xxxx xxxx xx--
764-01-04 xxxx --
So just to clarify, do we copy all the values including the" -- " or only the xxxx values?
Naveen
Naveen
Good Afternoon Guys, I did the Cruise Control Switch today (ML3Z-9C888-DA). After swapping , seems like none of the buttons on this side are working ?
Is to more of a faulty part or i need to do any FORSCAN update ?
PS - I switched back to original one without Radar distance button and older one is working fine. I guess they sent me a faulty part ?
ZSC100
Zach
Tulsa, OK
Electrical Engineer
No, there is one change you need to make in the SCCM that tells it what button module you have. Make that single change and it will work. I believe you can do this in the easy mode of configuration for the SCCM.
Naveen
Naveen
Thank you @ZSC100 for jumping in.
After installing the new Cruise Control Switch today (ML3Z-9C888-DA). None of the button on it were working (Volume Control (+-), Lane Keeping etc).. so i thought its a faulty piece .. I was under the impression the SCCM module changes are for Radar distance button only.
So none of the button's on new one will work unless FORSCAN changes are done ?
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Correct, there is a configuration parameter in the SCCM It has to be set to the part of each button module in the steering wheel. This has nothing to do with anything else.
Naveen
Naveen
Thank you buddy. Appreciate your quick reponse on the same.
I will retry this tommorow and post updates.
