Hack for lowering spare tire?
SpaceEVDriver
Arizona
I use a hex shank socket adapter, an 18” hex shank extension, and a 13 mm 8-point or 14 mm 6-point socket. To avoid the the socket coming off inside the plastic receiver tube, I sometimes use the short part of the jack kit to turn the crank.
Ford F-150 Lightning Hack for lowering spare tire? PXL_20251012_000248094.RAW-01.COVER
Ford F-150 Lightning Hack for lowering spare tire? Screenshot 2025-10-11 at 17.10.33
RLXXI
3rd rock
Automotive Technician
I wouldn't recommend anyone shopping with these people. The order was missing parts and they could careless.
Wow! I've been purchasing from them over 10 years with no issue.
flabrent
Brent
Florida Panhandle
'25 Ford Lightning Flash Job 2
Of the pictured items on their site, they shipped only the jack, item #3. They are claiming that the jack tools, tire tools, and carrying pouch are not included, items 2, 5, 6, & 7.
So I'm going to ship the jack back and see if they issue a refund.
I'll give them a couple more weeks, on top of the two weeks I've already been dealing with them, but I have a feeling I'll end up disputing the charges with AMEX.
K6CCC
Glendora, Calif.
For $20 you can get a corded impact from Harbor freight.
Add a VERY long extension, and an adapter to run the factory jack, and that $20 would VERY handy
The inexpensive driver sounds like a good idea to go along with the long extensions and socket.
if you get a flat
I wish I could say that part. In the eight months I have had my truck, I have had three flats. First one something skittered across the freeway and hit the RF sidewall - 4 inch split. Instant 0 PSI. Freeway Service Patrol was there in minutes and changed the tire. Obviously had to replace the tire. Second one was a screw in the RR right on the corner between the tread and sidewall. That one was slow enough I could drive a couple miles to get off the freeway. I called AAA and they got there in 10 minutes. Shop plugged it and so far it's holding. Third one was last Saturday and something damaged the tread while on a gravel road. Middle of nowhere so that one I changed. This trick would have been handy and saved some time!
Already planned to replace all four (or five) tires with off-road tires in the near future.
RLXXI
3rd rock
According to their website 2,3,5,6,and 7 are included if you selected #1 grouping.
https://www.fordpartsgiant.com/parts/ford-jack-asy-lifting_nl3z-17080-b.html
I'm sure they'll make it right.
ssteven365
Scott
Charlotte NC
2025 F-150 Lightning Flash
May be useful for some…I wanted an easy, no thought tool for lower my aftermarket full size spare.
I got this on Amazon: https://a.co/d/0cPOpoF9
Fits in the plastic tube and engages the lowering mechanism easily. A 22mm or 7/8 ratchet both fit on the end to turn it.
