Just purchased used F-150 Lightning Lariat ER - Vehicle is fleet locked
Dexter
Nashville
23 F150 Lightning XLT
So this happened.....probably reason for no updates, my truck is at 22326.
Special Service Message 53966 - 2021-2025 Various Vehicles - SYNC4 - General System Performance And Stability - Programming No Longer Available
Jun 20 2025 Some 2021-2024 Ford and Lincoln vehicles equipped with SYNC 4 may not be able to perform an update to the accessory protocol interface module (APIM).
This may be due to the software in the APIM. Ford Engineering has de-activated the ability to update these SYNC 4 APIM modules and as applicable, the Ford Diagnosis and Repair System (FDRS) will not present an update for the APIM module. Some existing directed repairs may be impacted, check OASIS before attempting any specific TSB repairs and landing pages before attempting any specific FSA repairs. For any vehicles repairs requiring a software update that includes an APIM update in the programming sequence, if the 5-digit product code for the APIM software is equal to or lower than 23187, do not attempt to update affected modules at this time. To determine the 5-digit product code for the APIM software on the vehicle, while the vehicle center display screen is powered up with ignition in run or accessory, go to General Settings > Select About SYNC. Find the 5-digit code, example “ SYNC 4, Software Version: 23187_PRODUCT”.
hb.sagen
Henning
Norway
F150 Lightning 2023 Lariat
That’s the same version I am stuck on.
theawesomegamer
theawesomegamer
Alton
Utah
2023 F150 Lightning Lariat ER w/ Max Tow
I think that’s the version I’m on.. when did they post this message? Jun 20 2025 seems like a while ago.
Jesse-Infotainment
2024 F150 Lightning Platinum
Its so crazy.. I helped MANY people get passed that version when I could. There is literally no reason they cant release the updates.
Jesse-Infotainment
I would love to hear it..
I just know back when I could Once the gateway installed, it was LkJ strategy file that had to be updated for the ICE trucks. Once it reported all updates came after. No install issues and in fact a few got the EL APIM update via OTA. Every Truck as soon a LKJ was reported as the strategy the update sequence hit no issues. I helped a few Mach E get passed it also. I want to say it was LKJ for the Mach E also.
Oh well Im sure there is a reason. I never encountered a reason to not do them though.
Dexter
Nashville
So....what is this LKJ strategy file and how do I get access to it? It's part of the GWM? Can I update it with FORScan?
Also, I had another call with the Ford Update (OTA) team....they are very helpful with giving information, but can't kick start updates (this we all know). They were able to tell me what modules on my truck were in need of updates...(the ones with the star are directly impacted by TSB 25-2105)
APIM *
ABS
ACM
BCM *
BECM
DCDC
GWM *
HVAC
OBCC
PCM
OBDII X3 versions down
Also I now have a case open with the update team and my dealer has been looped in. The OTA team also said that SSM 53966 Special Service Message SHOULD NOT prevent OTA updates but I don't know what to believe at this point. I may try to get an engineering ticket opened with this as it helped with my fleet lock. So now I'm patiently waiting for my first OTA update....
Thanks everyone....happy thanksgiving and such,
-Dex
theawesomegamer
theawesomegamer
Alton
Utah
APIM *
ABS
ACM
BCM *
BECM
DCDC
GWM *
HVAC
OBCC
PCM
-Dex
Good luck with them trying to open a ticket with engineering. Your dealer will receive a paper that says “there is no updates for your truck at this time”
The OTA team is helpful (only one guy) but they can’t do anything. That’s up to the dealer and ford and they won’t do anything.
hb.sagen
Henning
Norway
Is this something we can apply our selves, in any way? We have 1000 imported trucks in the EU, by Ford, that is stuck on 22326.
Jesse-Infotainment
I used to be able to help.. I cant anymore.
hb.sagen
Henning
Norway
I have talked to Ford, and they have confirmed I should receive OTAs and even given me the version of Sync I should be on: 24127 with OTA 10.1.0
But they can’t explain why I don’t get updates. How do I convince them to test the LKJ strategy for the gateway?
Dexter
Nashville
Hey All,
It's been a while, but I've got news. After having the case opened with the OTA team and waiting 8-12 weeks for the OTA's to show up, they never did. So I went to my local dealer here and gave then a writeup stating exactly what was happening (ALL the bugs from an unpatched 23 Lightning) and the OTA Team case number....and they proceeded patch the sh^t out of my truck!
VERIFIED NO RECENT OTA UPDATES, VEHICLE DATA SHARING WITH FORD IS WORKING AS VEHICLE DATA IS CURRENT- FOUND GWM, APIM AND TCU OUT OF DATE- PERFORM SOFTWARE UPDATES ON ALL MODULES- FORD OTA CASE #CXHXXXXXXXX * UPDATED TCU, APIM AND GWM, BCM, ACM TO LATEST CALIBRATIONS, - UPDATED ALL MODULES PER CASE# CXHXXXXXXXX
Working with the OTA team and updating all of these modules will "HOPEFULLY" get me on the automatic OTA queue.
I've got to give that dealership props, they got all of this done on one day! Ford of Columbia in middle TN.
Fingers crossed.
Current SYNC version is 24127_PRODUCT Revision 1270.
So what parameter is OTA 10.1.0 where do I find that?
Thanks again to all who have helped out....you guys and gals are awesome.
-Dex
