What is this?
dpwmc93
Dennis
West Bloomfield, MI
Ford F-150 Lightning Flash
Senior IT Support Specialist II
So I just bought a 2025 Lightning Flash and under the back seat in the storage area there is this piece of plastic that I’m not sure what it is…anyone have an idea?
Ford F-150 Lightning What is this? IMG_4624
RLXXI
3rd rock
Automotive Technician
Yep front plate mount, mine came with it as well.
Deleted member 4362
Guest
It’s the front license bracket. Unfortunately it looks like the dealer grabbed the other hardware out of it. Should have been screws and rivets with it.
chriserx
Louisiana
it took me a minute to figure it out myself
bryce
Bryce
2023 Lightning Lariat ER, 1999 Boxster
Front license plate bracket. My car just had the bracket, no hardware and not installed by the dealer even though Oregon requires a front license plate.
the install is easy. There are two dimples in the plastic trim which are easiest to see with the frunk open. I just drilled the plastic with a small starter bit and the used two stainless screws to attach the bracket. It integrates well with the front of the vehicle as there is a relief in the trim at the lower edge of the frunk where the bracket fits perfectly.
Brent@ANParts
Diamond Sponsor
Brent
www.autonationparts.com
Ford Bronco
Marketing
Lucky they left it back there instead of on the bumper! Some places will install it, I prefer making that decision myself.
rockfish
Rock
Shoreacres Texas
23 Lariat, Star white. ER Max tow.
aircraft mx.
yeah mine came with it as well installed with 3m double sided tape, no way in hell am i drilling holes in my $70,000 truck. 😉
jwrezz
1996 Ford ExplorerXLT, 2006 Subaru OBS LLBean, 2024 Ford F150 Lightning Lariat
Teacher/Firefighter
FYI if you don't want to drill holes, I used 3m double sided foam tape to mount mine. It's been a few months and a month with temps down to the high 20s a bit. Hasn't fallen off yet!
bryce
Bryce
if you drill where it is marked, and take care not to plunge, you can use screws to install the bracket. If you take the bracket off the screw holes are all but invisible, unless you are entering the truck in a concours event.
dpwmc93
dpwmc93
Dennis
West Bloomfield, MI
I live in Michigan so no front plate needed
jwrezz
Teacher/Firefighter
I just don't like making holes if it's not needed. The 3m tape comes off with work, but leaves no residue. I mounted my glowing googly eyes with it for Halloween.
bryce
Bryce
Well, if the googly eyes fall off, no big deal. But if you are in a state with a mandatory front license plate then having the tape fail and losing the plate is a big deal.
RLXXI
3rd rock
I'm in the no holes group. They sell some 3m weather strip tape that's atomic strength, oems use it for door trim for years. Seen on vent shades also. Prep the surface right and it ain't going no where.
Can be removed with great effort.
