UPDATES NOT COMPLETING DUE TO BATTERY LEVEL
metzgerc
Craig
Biloxi
lightning
MY23 Lariat. I tried to just charge 12 volt battery and let schedule update take over but it failed. Called Ford prior to below steps and they said run the truck for 45 minutes then let it update on schedule but had already done that without success.
Here’s what I did to get the frunk security update on Sep 9 to succeed:
-Charge 12 volt battery with external $25 trickle charger(see other posts on where to connect charger) overnight.
-Start charging the vehicle.
-Initiate software update “now” while vehicle is charging.
Worked on first try. Will update post if next update fails with same error of low battery issue.
Storm Breaker
Norm
F-150 Lightning Lariat
truck driver
how do you trickle charge with the frunk closed
Adventureboy
I simply closed the frunk on the extension cord initially. After that I permanently mounted a battery maintainer on the back of the access panel and ran a cord from the 12v battery bay to a permanently installed 120v socket in the front air scoop. I plug it in any time I'm not going to drive for a couple of days.
Ford F-150 Lightning UPDATES NOT COMPLETING DUE TO BATTERY LEVEL 1757970516066-d
Reactions: chl
trev5150
Banned
Banned
Banned
Trev
Pilot of pilotless things
You should all have one of these and use it at the first sign that updates aren't going or every few months:
Battery Tender
Ford F-150 Lightning UPDATES NOT COMPLETING DUE TO BATTERY LEVEL 61nddgtbkaL._AC_SL1200_
GrokTime
Sean
Ithaca, NY
2022 F150 Lightning, Rivian R1S 1st Gen
Thanks everyone for your help. After trying everything else I finally bought the above Battery Tender Junior. I attached it to my battery and a few minutes later it turned to flashing green (battery at 80%) and a few minutes later solid green (battery at 100%).
I ran the update and it installed with no problems. Better yet, I was immediately offered Bluecruise 1.4 and ran that update and that succeeded as well! Finally!
However, in the end doesn't this mean that I need a new battery?
Storm Breaker
Norm
truck driver
nothing worked for me. the tender never turned green. it read 14.4v when truck turned on and with truck off only read 12v. idk what im doing wrong. seems simple enough. plug it in, attach clamps at the points pictured in this thread then press the button. I must need a new battery. Its a 22. one of the first off the presses.
Storm Breaker
Norm
truck driver
Welp wish me luck. just bought the die hard battery. ill install tonight. reset the settings for a new barrtery and try the install again.
Marc
Marc
Roswell
23 Lariat and a 25 Rivian R1S
insurance agent
Back from the dealership after 4 days. My battery ended up fine. They repaired my passenger seat which took the time. They updated all my missing updates . I figured it out the issue is with short trips and long time between charging sessions that ran the 12 volt down low. I guess I will go back to my old ways of always be charging.
Storm Breaker
Norm
truck driver
Worked lika charm. Replaced the stock battery with the die hard. plugged it up for my normal hvb charge and let the auto update commence and the update completed
21st Century Truck
Martin
LVB BMS reset:
  • Make sure 12v battery is fully charged (drive an hour, or after an hour actively charging the HVB)
  • Start Accessory mode
  • flash high beams 5 times
  • step on brake pedal 3 times
  • red battery icon on dash should flash 3 times
If the dealer changes the 12v battery, they should do this, but they don't always. If they plan on keeping it overnight, there is a good chance they will - Just ask when you pick it up.
I just changed my 12V battery. Then I tried this BMS reset procedure. Did not work for me after multiple tries (no red battery icon glashes at all).
Any suggestions?
Any suggestions?
Here is the process I have been suggesting (but not used personally, #6 seems to be the only difference - and waiting on step 2). Don't rush and I think #5 may take a couple of seconds - don't turn off until you see the 3 flashes):
  1. Press the start button without stepping on the brake (Accessory mode).
  2. Note red Battery icon will come on in the instrument panel.
  3. Flash the highbeams with the stalk 5 times.
  4. Press the brake pedal 3 times.
  5. Check the red battery icon on the instrument panel to see that it flashes three times.
  6. Press the start button again to turn the truck off.
To check, turn truck back on and use CarScanner to see value of 12V battery reset. If done correctly, you will see 0 days.
metzgerc
Craig
Biloxi
lightning
Any suggestions?
I ended up taking my 23 Lariat Lightning back to Ford Dealership they said the battery failed the testing and put in a new one.
21st Century Truck
Martin
Thanks. This is the exact non-FDRS process I used. No joy - the red battery icon did not ever blink for me.
Adventureboy
I've used the process twice on my 2023 Lariat about 1.5 years ago. Once when I started getting excessive drain messages, and once when the battery was replaced. It worked both times for me.
