Sahit
- First Name
- ROBI
- Apr 23, 2025
- KOSOVO/WESTERN BALLKANS /EUROPE
- F150 Lightning 2022 LARIAT
I need help with my 2022 Ford F-150 Lightning /Lariat. The 12-volt battery keeps draining even after replacement, and the truck will not charge it.
I’m getting a persistent U019B – Lost Communication With Battery Charger Control Module (BCCM).
I cleared the DTC using Forscan, but the code comes back instantly, and the truck does not charge the 12V battery at all. It only drains it until the voltage drops completely.
I have already installed a new 12-volt battery, but the problem remains exactly the same.
The main issue is that I live in Europe, and there is no official Ford service for the F-150 Lightning near KOSOVO, since my truck is a US. import. So I currently have no access to certified diagnostics for the high-voltage or DC-DC charging system.
If anyone has experienced this issue — or knows typical causes for U019B on the Lightning, such as BCCM failure, DC-DC converter problems, wiring/CAN bus faults, or software issues — please let me know what I should check next.
Any guidance or experience would be greatly appreciated.
Thank you!
Thank you!
