Unable to Set Charge Limit
Tralfaz
Socal
‘24 Flash
Hello,
I had the issue with my 2024 Flash built in December 2023. Dealer couldn’t figure it out either. Found a similar thread listing CSP 24B48 August 22, 2024 with build dates December 15, 2023 - April 4, 2024 which reported the problem and the SW fix. I took a hard copy of the CSP I found with a google search and requested the described updates at the dealer. They updated the PCM. It allowed me to set charge location and limits. Covered under warranty.
The need for this CSP did not show up in my FordPass app.
I would assume the previous owner may not have used the function and lived with it. I hope this solves your issue. My Flash is the best vehicle I have ever owned.
Hello,
Now I recall this issue with certain model year Lightnings!
I hope the @Sbpatel82 has success with the delete & rebuild of the charging scheme after the 12v reset, but if the problem persists this CSP might be the true solution.
https://www.f150lightningforum.com/...set-charge-location-time-etc-fix-24b48.20979/
