teksavy
- First Name
- Ed
- Mar 8, 2025
- Reno, NV
- Website
- projects.teksavy.com
- 2022 LIghtning Lariat, 2023 Chevy Bolt EUV Premier, 2024 Chevy Equinox
- Occupation
- Retired
UPDATE (1/20/26): Solved... see post #11. Thanks to the help received here.
______________________________________________________
Hi:
I'm hoping some of the FDRS gurus can help.
The problem: My father-in-laws 2022 lightning (5/2022 build date) had 22 outstanding updates from Ford. (I don't think it has ever been updated except for the OTAs from time to time.) I was able to update a few modules (PCM, SODIM, TM, etc.), now I can't update *any* modules. I get programming failed on multiple modules- DSM, FHM, ABS, etc. Usually once it gets into programming mode (dash goes dark and the "humming" begins), it usually fails right away- on multiple modules.
More detail:
Here are some of the errors I get:
Any ideas are appreciated!
-Ed
Hi:
More detail:
- I'm using a high-end clore automotive 125A charger/power supply while programming
- I just replaced the AGM battery with a new Ford AGM unit and is working great. The old battery was over 3 years old and would be at 11.6V in the morning after just sitting. So it needed replacing anyway. Also the OTAs would never complete because of the low battery voltage.
- I'm using a genuine FDRS subscription on a fully updated windows 11 laptop and a Mongoose Ford cable that has worked flawlessly on my 2022 Lightning. I even updated the firmware in the instrument panel to get the charge rate display over 7 hours straight. So I know this setup works.
- FRDS did update itself to version 46.5.6 right before I tried programming his truck.
-Ed
