Gloss Black powdercoat OEM Lariat wheels looks fantastic!
csukoh78
Nope
SE USA
2023 Ford Lightning Lariat ER
Wheels look sexy as hell. If you don't mind me asking, what did the powdercoatng set you back?
$400 total at my local automotive powdercoater.
mb0220
Matt
2022 Lariat ER
shockingly good! It does not ride as a semi – lowered truck at all. The slop and floating feeling is completely gone. It handles bumps very well and is absolutely flat around corners.
Although the suspension has less travel, the computer/app adjust to road conditions very quickly (thousand times a second?) The rear suspension is very very close to the bump stop and I did not even lower it the full 4 inches or so. I may end up lifting it another half inch or so. Icon recommends 1 inch of thread showing.
The replacement bump stop they have are very good. If you do happen to bottom out, there's no shock or jolt because the suspension handles it so well. overall it rides tighter, smoother with less cushion feel. It really shines around curves though, no more worrying body lean.
The "fit" of the wheel within the wheel well is so much better with your setup.
kbuicker
Kevin
Dallas Texas
2022 Lightning
Same tires here, going on 10k miles. No range hit. I wouldn't think there would be considering they're same width/height etc. They are very smooth and quiet and properly rated for the weight of the Lightning. Let's hope they last!
csukoh78
Nope
SE USA
That's a steal of a deal if they look good and hold up!
it's ultra hard black gloss powdercoat. Off road grade. Supposedly it's 10-20 times harder than enamel paint. I expect these will look new forever.
Quantum
Banned
Banned
Banned
Washington State / Malibu
2026 SEV TB ER
Accredited Investor
Please share how much is it to do the wheel treatment - and how would that treatment look on the side and back rails which are dirt magnates - albeit slip resistant designed + wheel wells need a ceramic coating or something since dirt clings.
csukoh78
Nope
SE USA
What?
csukoh78
Nope
SE USA
Time for a garage space so weather doesn't abuse it.
But my wife's delicate bottom likes a room temperature car so she is in the garage. Also my truck doesn't fit
ChristianPeri
Reno, NV
2014 Ford Focus
Has anyone just done the reverse level and removed the rear blocks on the F150 lightning? Is that all you need to do to get rid of some of that crazy amount of rake from the factory?
RLXXI
3rd rock
Automotive Technician
There are no rear blocks like you speak of, it has an independent rear suspension not a solid rear axle.
csukoh78
Nope
SE USA
No. That's impossible. And it causes severe camber issues. Lowering the rear requires the Icon camber kit.
DoyouLightning
BK
Charlotte NC
23' lariat ER
Love the look of the black powder coat. I atoo have azure gray and pondering black powder coat vs bronze powder coat. Any one have experience with the bronze on the stock rims? I was quoted $600 for the bronze so not too expensive but wanted to see what the masses think?
