My first time using Car Scanner
roddiaz1
Rod
Pittsburgh
Do you have ABRP running? It may try to connect to the dongle first and that can cause problems
@B177y posted here that they installed an OBD Y-splitter and a second dongle to run ABRP and CarScanner at the same time
Thanks for the advice guys. It seems that the CarScanner software setting was set on WiFi, and all I needed to do was set it to BlueTooth. Now it is connecting to the VgatevLinlk MC+.
I appreciate the input.
chapba
mike
2024 Flash
fire
I cant for the life of me figure out how to get the ECU to connect with iOS with the MX+ OBD reader. Anyone have any tips??
chriserx
Louisiana
https://apps.apple.com/us/app/obdlink/id879636351
Downloading this will make it easier but it isn't necessary.
Manually first connect using
Settings -> Bluetooth
Press or hold connect button (don't remember which) on the MX+ and wait for it to popup in settings.
Once connected there, use CarScanner to connect.
If it's anything like mine that stays plugged in, you'll occasionally have to unplug the MX+ to reconnect if you encounter further issues.
chapba
mike
2024 Flash
fire
Yeah I’ve tried several times but will give it another go tomorrow. It connects to the first connection easily but continues to fail on the ECU (2nd) connection no matter what I try. When I was doing research the consensus was that the obdlink app (the one you linked) didn’t work since it’s an electric truck and they didn’t support it but I’ll try that as well. Looks like it’s the only way to update the reader as well and maybe that’s what I need to do?
chriserx
Louisiana
It does 'work' but it's not particularly useful imo, what you are encountering is what I was referring to when I mentioned unplugging it. Not sure the cause but it fixes it for me.
chapba
mike
2024 Flash
fire
awesome man! Thanks for the help. I’ll try it again tomorrow and see if your method works! You’re using an iPhone correct? I did read that android was easier to connect. Oh and I did get the scanner app to use with the reader so I figured not using the obdlink app was ok.
chriserx
Louisiana
Yup 11 Pro 26.3 Beta 3
mr.Magoo
2022 Lariat ER, AMB
Apologies for pointing out what might be seen as obvious, but the truck need to be on to be able to read any data.
If the truck is off, you'll still be able to connect to the dongle itself but the truck won't respond.
chapba
mike
2024 Flash
fire
šŸ˜‚ Yup it’s on. Just won’t make a connection to ecu. Did some more reading on the forum and looks like a reset, reinstall and/or re-connection work for folks that run into the same issue.
PJnc284
Garner, NC
Think i experienced a glitch in the matrix this morning. Remote started the truck and when I got in and pushed the start button, the SOC dropped, the battery power jumped up to 1MW and the coolant temp went negative before returning to normal. First time I've seen that behavior.
