F150 Lightning Torque App and PID list
Edit 9-15-25: Updated lists. Some conflicts with headers and updates that I am trying to iron out. The "trimmed" list appears to be working fully for me as of now.
As a long-time Torque app user (and fan), I’m starting a new thread to centralize and streamline the discussion around PID listings—especially for those of us using the app with Ford vehicles like the Lightning.
✅ Updated PID Spreadsheet
I’ve compiled and cleaned up the various PID listings available, combining them into a single, easy-to-use sheet:
Google Sheet Link -
Note: This includes the previous sheet shared by Firebase. While they haven’t been active on the forum for a while, the original document has been updated by others recently.
Major Changes & Improvements
  • Reformatted into Torque's preferred CSV import structure (Name, Short Name, ModeAndPID, etc.)
  • Leading "0" added to Lightning-specific PIDs so they appear at the top of Torque's PID list
  • Grouped and renamed similar PIDs for easier browsing (e.g., Charger..., HVB..., Tire Pressure LF, etc.)
  • Expanded short names (≤12 characters) and improved clarity
  • Added Header and Module info for most PIDs
  • Simplified or adjusted some equations
  • Standardized unit names
  • Refined some Min/Max values (e.g., changed Module Voltage from 0–50 to 0–5)
  • Included a few newer PIDs shared on the forum
  • Added some test PIDs (e.g., A/C Compressor 2)
⚠ Accuracy Note
Some PIDs appear to be unreliable or inaccurate. Use them with caution.
If you find any errors or anomalies, please report them in this thread so we can refine the list further.
Share Your Torque Pro Layouts
Torque Pro also supports importing/exporting dashboard layouts.
Feel free to post your screenshots or share your custom setups here—let’s help each other build better dashboards!
Current export (v10) in XLSX and CSV (change .txt to .csv) formats attached. It is recommended that users access the active Google Sheets document however as information may have been added since these files were attached.
On mobile use a browser to access the files to export the CSV, Google Drive app downloads a PDF.
Took a quick screenshot while I'm topping up from the day's errands.
I think I grabbed these using the spreadsheet you referenced. I'm definitely missing some of what you have on the consolidated over. Great idea to give torque a dedicated thread. I'm also a pro user, I really like the customization available. I'm still playing with the arrangement and trying to rename for better clarity.
Ford F-150 Lightning F150 Lightning Torque App and PID list Screenshot_20250601_190223_Torqu
As a side note, how is 44A equate to 17kW power? I'm a little confused, maybe I have some things mistakenly labeled?
Oooohhhh, yeah I was using 240v for my math and didn't consider that the power to the battery would be at pack voltage. The -43 is current flow into/out of the battery. When I'm driving its a positive number which goes negative during braking. So it seems a neg number is power into the battery.
teksavy
Ed
Reno, NV
projects.teksavy.com
2022 LIghtning Lariat, 2023 Chevy Bolt EUV Premier, 2024 Chevy Equinox
T H A N K Y O U very much for this! I appreciate the effort!
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Can anyone here comment on TorquePro versus CarScanner. I have used CarScanner only and I'm wondering if there is any reason to try/switch to TorquePro
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Both have their benefits.
Car Scanner comes out of the box with a better selection of PIDs. Display wise you have less flexibility and I find it more annoying to edit, although not by much.
Torque is slightly more flexible and let's you edit the PID list. It also has much much better logging, which is why I greatly prefer it.
I am able to add custom PID's to Car Scanner including Action PIDs to control custom hardware (accessories) added to the vehicle. Is this possible with Torque Pro, adding graphical buttons, like an auxiliary circuit control panel or airbag system control?
However, I haven't seen a good way to view/pull the PIDs from Car Scanner. I assume this is because that's what your $8 is for pro is paying for, the PID library, so it would make sense to me that they don't want you to be able to just export it. We all know we can sniff some of this data off the OBD2 port one by one if needed, but that's way harder than getting it easily in digital form.
galstaf
North Georgia
2015 LEAF x 2, 2022 F150 Lightning Lariat ER (511A trim)
community offgrid training
Hey ZSC,
Can you elaborate on this... what you did and why and how you did it?
You added a device to the CAN bus, assigned it an unused PID and control it using Car Scanner? Am I understanding this right?
Follow up also please: Can Car Scanner be used to make a screen full of quick shortcuts so I don't have to hunt thru several Ford display screens to make a change.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Hey ZSC,
Yes, I placed a custom ECU (any microprocessor with CAN txvr) programmed correctly on the HS1 bus of a Gen14 Ford Truck (a Lightning) and I programmed it to respond to extended PID requests at an address not used by Ford in their trucks. Once I got this working I started playing with Action PIDs which is just a standard PID request but with a different mode(8) than used for requesting extended PIDs (22). In this way full interactive dashboards can be created,,,, yes, similar to the native Sync4 setting screens.
Regarding your follow up please; yes, I can create dashboards with buttons to do things like toggle on and off features like pro power outlets, one pedal driving, drive modes, etc. The trick here is that I have to reverse engineer what messages cause these features to toggle, and then I have to program that messaging into my ECU to trigger when I send it the apprpriate action PID request. So, without a custom ECU on the inside of the gateway programmed to do so, CarScanner cannot do any of this :( Ford doesn't program any of it's modules to respond to Action PIDs from the OBD port, and if it did it wouldn't tell anyone.
galstaf
North Georgia
Wow.. interesting.
I would love a quicky menu to take care of my pet peeves that Ford can't be bothered with (currently prewarming my battery for charging which the 2022 firmware omitted apparently), one press Pro Power, one press FM radio, etc.
Question: what settings do you currently use?
How well does your system work?
galstaf
North Georgia
Would you have any interest in sharing the ins and outs of this project? I know its a pain in the ass, but maybe have AI write the bulk of it if you can feed it your notes?
Or at least a video explaining what you did and what you used to do it? Give us some inspiration?! lol
ZSC100
Zach
Tulsa, OK
Electrical Engineer
I'm afraid it's not worth it just for a few shortcuts. Especially when if Ford would just stop being dumb and give owners the ability to customize screens in their own truck.
All in you'd be looking at close to $1000 in hardware just to have shortcuts, Plus have to use CarScanner with a permanent MagicBox type device, it's not worth it unless you're doing something worthwile like EverDrive.
This is what I built the ECU out of: https://phytools.com/products/pcan-router-fd-w-phoenix-connector I will be publishing the Extended PID and Action PID software soon, but unless you're a programmer and handy with DIY hardware I don't see the economics for a few shortcuts.
woahmy
NE US
2022 platinum
Is there something special about that PCAN or is it just a convenient breakout of the NXP LPC4078 meant for industry where $450 isn't worth a second thought?
As far as I can tell, peaking the PCB in the user manual, it's the MCU, a SPI flash chip, and likely a USB/UART chip or the like
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Yea, it is way overpriced but comes with a CAN bootloader what is compatible with Ford's CAN network. I can push updates in the vehicle in 15sec. That has been invaluable for development. In the future, depending on how many of these we sell, I may switch to something way cheaper or build my own PCB.
woahmy
NE US
2022 platinum
Ahh, I guess you can program the PCAN directly over the Lighting's CAN?
I'd be somewhat confident in using an off the shelf micro and programming it via UART or whatever while it's hooked up to the can bus and I'm sitting in my driveway, and letting the system freak out for a moment while it's flashing (or jerry rig a simple bypass to limit interruption time). Although I guess the PCAN will handle message pass through right out of the box and while flashing?
