OBCC-AS.AU OTA
jamelski
Sacramento
2024 Lariat
Newest OTA. What’s weird is I got this after I had failure after failure of PT 25.11.4. Which never installed via OTA just moved onto this new OBCC. I wonder if the ford engineers figured out the issue and this new one supersedes it?
Ford F-150 Lightning OBCC-AS.AU OTA IMG_1390
Ford F-150 Lightning OBCC-AS.AU OTA IMG_1340
PJnc284
Garner, NC
PT-25.11.4 failed on me too the first time. Next day I got the sirius xm update which installed fine and then the PT-25.11.4 started downloading again. Hooked up the power supply I use with FDRS and kicked off the update. 9min of the truck sounding like a swarm of angry bees and all was good this time around
jamelski
Sacramento
2024 Lariat
Mine failed so many times that Ford stopped the update for mine. I took it to the dealer, and they claimed that “PT OTA” was attempting to update modules that the park pawl recall had already updated. This was causing the issue for me, and I had to wait for Ford to send me a new OTA. 🤷🏻‍♂️
Ford F-150 Lightning OBCC-AS.AU OTA IMG_1342
footballfalex
Alex
F150 Lightning 2024
Just got this one today, installed successfully with no issue.
Ford F-150 Lightning OBCC-AS.AU OTA IMG_2167
Realized I created a dupe on this, didn't scroll far enough, apologies everyone
jamelski
Sacramento
2024 Lariat
According to Ford Mobile repair tech this update also does the trailer recall, and it has been removed from my Ford pass out to anyone else. Check to see if yours removed if you got the OBCC
chriserx
Louisiana
Considering OBCC is not ITRM imma say not. Also consider I received this already, and still have the open recall. That being said, I just checked for the exact date of the OBCC in my history and it doesn't show that particular update even though I know it is installed. ¯\_(ツ)_/¯
I forgot the whole point of why I was posting anyway, I suspect there was a miscommunication and the update is applied when doing the recall. Or similar.
footballfalex
Alex
F150 Lightning 2024
Almost everyday since I've received this update my MyView has reset on the IPC -_-
priceb
Price
Western North Carolina
2023 F150 Lightning XLT SR
College Instructor
After this update I noticed I slight change in behavior after DC Fast Charging. I normally don't turn off the truck prior to plugging in, and once I unplug the truck is left in accessory mode. This morning, after unplugging, the truck was still on, not in accessory mode, and ready to drive. Anyone else notice this change?
jamelski
Sacramento
2024 Lariat
I meant to say. I called to get the update but the mobile tech look up my vin and said it was applied via OTA. It took like 3 days and the recalls is no longer on my ford pass 🤷🏻‍♂️ when he looked it into system it showed it updated with the OBCC update .bs or not it updated 🤣
jamelski
Sacramento
2024 Lariat
I’ll find out in 2 weeks when I go to so cal for vacation
BriyGuyUSA
Glyn
Atlanta, GA
2023 Lariat ER 511A Antimatter Blue
IT Stuff
So, until I get this update, should I expect my DCFC sessions to not be smooth? Slightly concerning lol...
chriserx
Louisiana
Just for the record, I assume that the issues are unrelated but several times since getting this update I get a 'Key not detected' error, despite the fact it keeps driving...
I wonder what it broke in the process lol.
