How often to charge to 100%?
JRDM2
J
2025 Lightning Flash
I charge almost every day to 80%, charge to 100% the night before two longer trips in the 4 months I've owned it.
FloridaMan655321
1973 F100, 2024 Flash
Curious, why disconnecting the battery for 20 mins? What does that do?
If you remember, or have worked in or around tech, when your operating system was having issues, the IT guy would have you disconnect the power from the computer, hit the power button to drain all the electrons/capacitors/etc.., then plug it in and power it back on. It’s kind of like that with vehicles these days. They are like operating systems of the past and sometimes you need to drain all the ‘juices’. Giving it the ole ‘cold boot’
Upstate
Kevin
NY
F-150 Lightning XLT
When the trip will require it, I charge to 100%.
For daily use, it's 90%. I note that I am charging at home, which is not a superfast DC charging system.
When using public chargers (superfast), I usually stop around 80 - 85%. Going beyond that adds significant amounts of time to the public charging experience. That's less convenient and, well, be considerate of other drivers who may need the charging station.
Note that winter range plummets, like by nearly 50%! So in winter, it's almost always a 100% charge at home.
Also, I usually keep the vehicle plugged in. No harm if it is not charging, and if it needs it, it's there. Also, for warming up in cooler weather and cooling down in warmer weather, I get to use house current instead of vehicle charge. That extends the range a bit more too.
Red_Lightning
Tony
Arizona
2025 Lariat Lightning
Note that charging to 100% and then using the vehicle in a day or two is not bad for the battery.
Your statement is false. A higher state of charge for our NMC batteries WILL degrade the battery. It is physics.
Also, don't quote "battery health". It is a proprietary marketing term that Ford made up as a pacifier for people who don't understand lithium ion batteries. The number you want is percent degradation, and it is non-trivial to measure.
Obviously time is factor as is ambient temperature. For people like me in Arizona, it is a much bigger problem than for someone up north.
The relevance of that battery degradation depends on your use case. For someone on a lease with no intention of keeping the vehicle, the extra degradation is meaningless. For me, I plan on keeping my Lightning for more than 10 years. Therefore, I charge the truck daily for my regular commute with the gentlest cycle possible while keeping a buffer for extra driving or an unexpected charging issue.
windydrew
Kansas
23 Lightning Lariat ER
Solar Installer/Electrician
I charge mine to 100% every day and use a fast charger daily and have 85k miles on my truck with no noticeable change in range. Pretty sure my SOH was 98% last I checked. Ford did a great job with these batteries.
mr.Magoo
2022 Lariat ER, AMB
Sometimes these discussions have a tendency of venturing into the extreme.
There's probably a middle ground between your battery losing all it's capacity or going up in a plume of smoke and being completely harmless, but our discussions rarely reflect this.
While we know "storing" a battery at a high SoC is bad (in the lab /accelerated tests anyway) we really dont know how bad it is to leave it for a day or two.
We make the conclusion that if it's bad long term it must be bad short term and while it isn't incorrect per se, it isn't the entire truth.
It's like alcohol, just because you go on a weekend bender with your buddies, it doesn't mean you'll die of liver failure at 40, but keep it up every single weekend from the age of 21 and you just might.
Sure, anything over 50%, well even lower than that truth be told but then you run into other issues.
Point being, yes, they degrade faster the higher the charge level. 80% is worse than 70%, and 90% is even worse than 80%. So every SECOND at 100% is worse than 99%.
But in practical use occasionally letting it sit at 100% for a day or two is in the noise compared to parking on a freshly coated black parking lot vs an older lighter colored one, or not preconditioning a warm battery on the way to a charger, or... you get the point.
wescravinshocker
Jon
2023 LIGHTNING XLT
Trades
Just wondering if it's good for the battery to charge to 100% every once and awhile. I've had the truck since August of last year and it was 100% when I picked it up. I did a max charge for one mid range trip and that's about it.
I normally charge to 80%.
I charge to 100% every other week at home. When I go up North, and need the range, I DC Charge to 90%, once or twice per month.
Literider150
Brad
67 Deer Trail
2024 F150 Lightning
Unless there’s a good reason not to have it on the charger, it’s always on the charger. I have a default max charge level of 90%. I’ll charge to 100% at least once every couple of months and every time I need to go on a long trip, which also seems to be at least once every couple of months. So at least once a month the truck is charged to 100%.
Note that charging to 100% and then using the vehicle in a day or two is not bad for the battery. Storing (for many months) at 100% can be detrimental. And charging to 100% on a DCFC is really slow (relative to 0% to 80% on the DCFC) so people recommend you don’t do that.
All of that means people conflate all of these things into an idea that ever charging to 100% is bad for the battery. It’s not. Charge to 100% whenever you need it and sometimes even if you don’t need it and will be using the vehicle in the next week or so.
I wouldn't think that Ford would have the AC default charge limit of 100% if it is bad for it. If I want to only charge to 80% I have to set a temporary limit each time I charge at home. But that isn't necessarily true. They might just expect you to change that every time.
The owners manual recommends 90%.
If you set a charge location you can set the charge limit for that location. That way you dont have to set a limit every time.
100% is 131/143=91.6%....
:rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :) :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes:
bc1
McPherson, KS
I believe that's correct for the 131 kwh battery. It is already setup for 90/91% as I believe full charge is in the 143/144 kwh range with the rest in reserve. I'll let the resident battery experts explain this further. The 122 kwh battery is really higher than than as I recall.
I never saw a published full capacity of the smaller Flash battery.
bc1
McPherson, KS
I forget if it has one less cell or what the deal was and I'm thinking the cells are around 9 kwh or so. Guess we need everybody to chew on Ford's reserve capacity and how it affects charging.
Literider150
Brad
67 Deer Trail
2024 F150 Lightning
Oh thanks for that. I didn't realize that. I mostly charge at home so I was referring to my AC charging. I suppose that setting has to be done in the truck, not on the app?
