Tire Size and Range
Stovepipe001
Johns Island
2023 Lightning Lariat 2025 Lightning Platinum
I have both a 2023 Lariate with 20 Inch OEM wheels and tires and a new 2025 Platinum with 22 inch wheels and Michelin Defender 22" tires. I swapped out the tires on the 22 Lariat with the Platinum tires and noticed a decrease in range of approximately 15-20%. At 90% charge on the 25 Platinum I noticed the range to be approximately 285.
2023 Lariat with OEM wheels and tires (20") was normally 320 at 90% it is now 290 at 90%. Reading up on the effect of weight at each tire I should have expected this to happen. Has anyone come across a set of 22" wheels and corresponding tires that are light enough and LT (light truck) rated that approximate the 20" tire range?
Ford F-150 Lightning Tire Size and Range 2025Plat#3
Ford F-150 Lightning Tire Size and Range 2025Plat#2
The GOM is not a reliable indication of range. Drive both on a controlled route under identical conditions and compare the MPK.
And yes, the EPA range on a Platinum is slightly lower, generally attributed to the tires/wheels.
mr.Magoo
2022 Lariat ER, AMB
Not sure what the offset on those wheels are, if they protrude much more than OEM, but I notice a 5-10% drop in efficiency when going from OEM Lariat to OEM (non-aero) 22s and my 22s are Heavy!, like 75-80lbs.
So I think you're looking at other things than just weight with your setup.
tgbuckner001
Thomas
US
F-150 Lightning 2025 Platinum Trim
Will a non LT tire be acceptable for the weight of a Lightning?
Skidrowe
Gideon
2022 F-150 Lightning ER, 2014 Honda Pilot
I can't comment on wheels because I kept my OEM wheels, but I replaced the grabbers with these Toyo Open Country AT3 EV tires and haven't noticed a measurable difference in range compared to the stock tires. Tirerack link. It's nice that they also look way better than the grabber tires.
Ford F-150 Lightning Tire Size and Range PXL_20260214_161707231
KurtsRPMGarage
Kurt
Orange County, CA
The stock tires are not LT rated so I'd say so. Every tire is different though so look at the actual weight ratings and compare to the OEM tires before slapping a set on. I went with a set of goodyear electric drive AT's in a 275/65r20 (non LT) and have been very happy with them.
Robocop
2022 Platinum; 1962 Lincoln Continental
are you comparing the range on both vehicles and scratching your head?
There is another thread here somewhere about how the earlier trucks have a different version of the GOM software from the newer ones, so you might be having a problem right there. The numbers won't ever be apples to apples between the 22 and the 25 in my understanding, everything else being equal.
the OEM 22" Platinum wheels are very heavy. do you know how much those gold aftermarket wheels you have there weigh? They look cool but what do they weigh? is the OEM 22" setup and the aftermarket 22" setup the same weight?
For road cars, reducing weight is one of the most effective ways to improve efficiency, as every extra 55 pounds (25kg) can increase fuel consumption by roughly 1%. Weight ranks above the #2 most important factor, aerodynamics.
The only way to cut unsprung weight without compromising wheel strength is by going with a forged aluminum wheel, and at 22" it gets expensive. I suspect the 20" is the sweet spot between looks/weight/efficiency but I won't be able to measure it until later in the summer.
K6CCC
Glendora, Calif.
I gather that they are the same size as the original 275/60R20?
That's the tire I'm looking at except I will likely go at least a little larger in diameter.
tgbuckner001
Thomas
US
I know the tires are 53 lbs each approx 14 lbs heavier than the MOM'S. I assume the gold wheels are roughly 10 lbs heavier. So Im ~25lbs per corner heavier or 100 lbs overall. Im site this accounts for a noticeable reduction in range.
Going forward, Ill either get another set of wheels/tires that are #1 more aerodynamic #2 lighter. Since I only have 5,000 miles on the '25 I'll for sure end up getting a road trip set of rolling tires/wheels and sell these to an F-150 enthusiast.
tgbuckner001
Thomas
US
The ones I have are 275/50R22
Skidrowe
Gideon
Yes, I put on the same size as stock. 275/60R20.
Robocop
I'd suggest going with the recommended tire size and get a tire designed/optimized for street use.
I've got a '22 platinum as well and I plan on doing the 'downgrade' from the 22" factory setup with the General Grabber tires and swapping out with an aftermarket 20" wheel with a set of the Michelin Defender LTX M/S tires in the OEM recommended size.
Think about cutting weight first: the wheel weight of the new setup cant exceed the weight of the old setup if you want to see efficiency gains. if this is the case, aerodynamics won't get you any efficiency gains.
the OEM wheels are forged aluminum. what make/brand are the gold ones? what material are they?
It is mindblowing to me that the gold ones weigh more than the 22" OEM platinum wheels! with the extra weight of the tires, the total weight of the package seems crazy to me.
tgbuckner001
Thomas
US
The Gold ones are forged Aluminum. Im not sure of the weight as I didn't weigh them when I received them from the supplier. Communications with somebody in Asia is tough as I've asked many times.
I took the OEM wheels and put on my '23 Lariat Lightning. Soon I'll take the LT's off and replace with something lighter and more efficient and will find out.
It wasn't until I noticed the difference in range did I start paying attention to efficiency and learning. Im getting a bit old to think clearly from the onset at 75.
