SOBDM Failure
I guess we need a comprehensive list of all the acronyms and their functions?! :)
Jesse-Infotainment
2024 F150 Lightning Platinum
here is a list of the modules on a 24 Lightning
Ford F-150 Lightning SOBDM Failure 1776027754380-xn
But The SOBDMB and C are the Motor controllers.
Sobdm A On Board Primary Charger
GFM3 7.2 Inverter
GFM2 Second On board charger for 22-23 trucks
Wisconsin
2022 XLT Lightning
My 24 Flash with 4k bricked with the same issue. SOBDM Module shorted out when I plugged in to charge at home. Also fried a fuse on the HVB. Truck was in the shop for 3+ weeks. Ford covered the repair.
Thank you for sharing.
Sobdm A is the on board Charger..
SOBDM B and C are the electric motor controllers(Maybe the wrong term but they are the motor invertor /controler?I dont know but they are related to the electric motors.).
GFM 3 is the second inverter for 9.6 pro power
GFM 2 would be the second on board charger that enables 80 amp charging
Thanks for clarifying. The manual kept calling B and C inverter controllers (ISC) and I wrongly assumed ProPower. But yes the motors I believe are AC and so there would need to be an inverter that converts the DC to drive them.
Ford Motor Company
Official Ford Account
F-150 Lightning
@Ford Motor Company the OP is experiencing inconsistency of warranty treatment PLEASE HELP !
On it!
Thanks for everyones comments so far. The comments from the dealer are as follows: "Accessed the diagnostic port & performed a scan. U3000:49 control module failure - SOBDM. Performed PPT AJ, AJ1=no. Found the secondary on board control module internal module failure."
The rest of the comments talk about removing the frunk, battery, battery tray and so on as part of the replacement.
I don't see any references to an A, B or C related to the SOBDM to share here. Since I was not able to charge from a 120v or 240v evse, I believe they replaced SOBDM-A (referring to bmwhitetx post) and thus why I thought it should be covered under the 8 yr/ 100k warranty.
I'll message you and grab some details.
Ford Motor Company
F-150 Lightning
Following up here. I've been in contact with @SolarAccountant and working through next steps. Based on the information provided the part should have been covered under the EV warranty.
Ford Motor Company
F-150 Lightning
Thank you to everyone for your replies and help with this issue. It is greatly appreciated and I was able to get refunded at the dealer today.
Happy to help!
JayF
Jay
Tacoma, WA
jay.jvf.cc
2023 F150 Lightning Lariat SR
Open Source Developer
@Ford Motor Company I got a used F-150 Lightning (from Titus-Will in Tacoma) a couple of weeks ago, and the active support on the forum here was a key reason why I was brave enough to get it! Thanks and tell your bosses I said you're great!
Farafield
Kim
Vermont
Ford F150 Lightning Flash
I think I am facing the same scenario. Suddenly can't charge at home on the 120v outlet, nor on the Emporia Level 2 I just installed. But fast charging works, thank goodness. I have an appointment in a few weeks. Any suggestion?
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Reset all your DTC's with FORScan or CarScanner, if that doesn't fix it you may have a failed SOBDMA. It's not common, but it has happened to a few people.
Farafield
Kim
Vermont
That is all Greek to me but I will do some research. Thank you!
ZSC100
Zach
Tulsa, OK
Electrical Engineer
If you don't want to mess with anything just take your vehicle by any autoparts store and get a scan/full DTC reset.
Tell them to reset first then scan, don't get a print out of the first scan it will be lengthy.
kubel
US
2024 Ford F-150 Lightning Flash (+9.6kW PPO, Max Tow)
Can I ask how much would the repair be out of warranty?
