Battery SOH - bragging rights or bullshit?
Adventureboy
@RickLightning I agree with your observation.
My 3.5-year-old MME settled around 96.5% during year 1 and has stayed there. My 3-year-old Lightning settled at 99.5% almost immediately after purchase and is still there.
Both HVBs are Extended Range NMC technology.
Both have the same patterns of charging to 85%-90% SOC daily (summer vs winter) and kept out of single digits, with a charge to 100% an average of once per month.
Driving patterns are different. MME is driven 6-7 days per week for daily commuting and an occasional road trip. Lightning is driven 3-4 days per week, but longer trips result in a bit higher mileage per year.
StevenC56
Steven
Fresno California
2024 Lightning Lariat Avalanche, 2017 Explorer Platinum
How do you check SOH? OBD scanner? If so, which one do most of you use?
All those VW driving on fumes stories brings back memories of being a teenager and barely having any money for gas, coasting down hills in neutral.
I drove an old used 1965 Mercedes 190E gas sedan for a while, with an inscrutable gas gauge that left me stranded several times, and a weird thermometer style speedometer that had Km/H and mph on the vertical scale, could never really figured out whether I was speeding or not on US roads, and to make matters worse, it changed color as it went up from green to yellow to red!
It barely had power to get up a highway hill with 5 passengers in it, but it was very comfy inside when on a date, and the young ladies were often impressed with it - little did they know, lol.
Here it is in 1970, pulled over in the middle of nowhere, no gas stations in sight, me hoping to make it out of the desert alive - apparently I did.
Ford F-150 Lightning Battery SOH - bragging rights or bullshit? remember-my-car-65-190-went-to-Woodstock-and-California
I had some adventures in that car, went to Woodstock 1969 in it with my brother and three friends and convinced the gate keepers we had band equipment so they let us pass - no they never checked the trunk because one of our friends had was wearing an official Woodstock staff jacket he had traded someone something for, lol.
Tickets: $6 per day - yes, we bought 2, two-day tickets before we went, alas
Gas for the trip at $0.35.gallon: 280 miles / 30mpg = $35 one way
Camping in the mud listening to Jimi Hendrix play the star spangled banner Sunday morning: priceless?
ClevelandBeemer
I suspect we have a much more robust cooling system to allow for towing.
I don’t know about this. I feel if the cooling system was truly robust, DCFC would be able to hold 500a longer.
It would be interesting to get an engineers perspective that was involved with the design.
Oh yeah, back to the topic...
Why the Mach-e is different - likely a different guess-o-algorithm is used.
As for the SOH numbers car scanner etc will give you, an educated guess-timate, but at least it's a data point to watch and give you a warm fuzzy feeling, or a feeling of dread, depending:
Ford F-150 Lightning Battery SOH - bragging rights or bullshit? the scream
So take the SOH number with a grain of salt but keep an eye on it anyway?
swajames
CA
Technology and software development
Why would the SoH number be bullshit? It isn't a number that's readily available to the driver, you can only access it via a scanner and your OBDII port.
swajames
CA
Our charge curve has already been improved via an OTA update to allow higher charge rates for longer. I saw higher rates post update than I saw pre. Maybe Ford will push things out a little further as more data comes in.
Maybe the term was used to insinuate Ford is fudging the number to make owners feel good?
State Of Health gotten from the Ford HVB BMS with an OBD canscanner app or similar, is just an estimate, not an exact number.
The BMS produces it using a calculation based on the measurements it collects and processes.
There can be small errors in measurement that accumulate over time, 'BMS drift.'
However, it is an indicator even if it is not 100% accurate.
Owners of EVs have seen the SOH numbers do funny things like go UP over time, due to recalibration of the BMS no doubt.
So while not technically BS unless the calculation were intentionally tampered with to distort the real number (like VW did with it's diesel exhaust calculation for example).
It is not as absurd as the state of the cat (dead or alive) in Schrödinger's box for example...closer maybe to determining/estimating the mood of your spouse after being together for many years?
ClevelandBeemer
Yes, but it is still thermally driven.
Ford F-150 Lightning Battery SOH - bragging rights or bullshit? IMG_9640
swajames
CA
Maybe. And of course we're all just speculating. But that would make more sense if the SoH calculation were generally and easily available to owners via the in-vehicle UI, but it isn't. This isn't the GOM or remaining energy calculation, it's an otherwise hidden attribute that requires owners to go to some effort to get it. All the other things you suggest may well be true, but none of us know if they are factored in to the SoH calculation anyway. My main point is it's not a number Ford needs to fudge as it's not readily available.
Ha, yes I guess so, that's true.
I suppose the only reason it is even readable with an the OBD scan is for Ford techs to see?
But these days, a lot of folks have OBD devices and use Car Scanner or equivalent APP, esp owners of EVs.
I also have a 2012 Nissan Leaf bought in Dec 2011, and it wasn't long before the LeafSpy app came along to show what the SOH of the Leaf battery was among other things.
I bought a new OBD device to do some Forscan tweaks - change the headlights to glare-free, turn off the chimes, allow PPOB with the truck off, activate silent mode, and remote front window up and down.
I haven't tried CarScanner, but it is on my to do list.
I will only freak out if the SOH number is really bad - but if it was, I imagine I'd already be seeing issues with the HVB, and I'm not, so it can wait.
FYI
Capacity loss is steepest at the beginning and end of the battery lifespan.
The average is from 1-2% per year just from age, and fast DC charging can decrease capacity faster than slow AC charging.
With my Leaf I have seen the average loss.
As part of their warranty settlement terms, I used to go in once a year for a battery test, but nothing abnormal arose so after the 5th or 5th year, I let it ride.
Well true, but all batteries are thermally driven unless charged well under their max.
Still, yours shows the normal lightning curve, higher power at the beginning, possibly until a certain thermal rise, more or less steady state, then the drop at 80%.
ClevelandBeemer
No doubt. I wasn’t not suggesting abnormal performance. Instead I’m merely questioning if the cooling system IS as robust as suggested.
Either way, I’m happy with it being the 400v system that it is.
My guess is with the cooling being on the bottom only the cells themselves limit how fast they can be cooled.
I have done some tests using water cooling to boost the efficiency of the AC system and didn't see any improvement other than AC compressor current dropping. I don't know if there would have been a difference if it was 110f out, but I dont believe so.
