What is your SOH, Mileage, and how do you use your Battery?
VirtualTed
Ted
Las Vegas, NV
2022 Lariat LR
Software Development
That's normal. The reason it shows 100% for such long time is because of it's eating the buffer, which is around 8% of total capacity. After that, it will start to eat the usable capacity....
Hmm. Not sure that sounds right. That would mean my battery has lost nearly 11% of it's total capacity which would definitely not seem normal. When I look up data in Carscanner, it clearly shows a difference between SOC and displayed SOC, so the buffer still exists.
electricpig
Tim
Northwest Arkansas
23 F150 Lightning XLT, Tesla Y
Getting nervous with my 2022 Lariat LR battery SOH since it started jumping all over the place.
(dates are estimates from when I first noticed it)
04/01/25 - SOH 100%
04/15/25 - SOH 99.5%
05/01/25 - SOH 97.5%
05/15/25 - SOH 98%
06/13/25 - SOH 96%
4% loss in 10 weeks seems a little extreme given that I've been at 100% for a loooong time until recently and treat it so well. Only DCFC 3 times and keep the charge anywhere from 40% to 70% on the Ford slow portable charger. Truck just hit 30k miles.
Any way I can diagnose the battery modules myself with Forscan or some other tool?
Thx!
Could be BMS drifting is an issue. Basically without going down to near zero, or 100% the BMS can lose track of actual. The SOH you are seeing is what the BMS thinks, and that may not be entirely accurate. Many people charge to 100% occasionally for this reason. I have read that the remedy is to run it to near zero, then in one continuous charge to 100% (meaning it shuts off on its own). This also has the effect of leveling all cells, meaning evenly charged which can throw off SOH calculations as well. Lastly, it's not just battery usage, it's also age of the battery pack, and environment, especially very high temps. But of course you may have a weak cell or two.
Try deep discharge to absolute full charge. Just keep it either end for as little time as possible.
Maxx
Maxx
04/01/25 - SOH 100%
05/15/25 - SOH 98%
06/13/25 - SOH 96%
Thx!
That does seem like a fast drop. Have you had any software updates to BMS in April? I am thinking if it stayed at 100% for that long, may be it has been lying to you all this time and now it is trying to tell the truth a little at a time.
VirtualTed
Ted
Las Vegas, NV
2022 Lariat LR
That's a great idea. I have only taken it to about 20% once and I took it to 100% about 4 months ago on a short trip, and then immediately began the drive. I do live in Las Vegas, and it started hitting 105F a day here, so that may have had an effect too.
I also recently had a couple recalls done (front sensors and front hatch control module on May 5). The timing is suspicious...
VirtualTed
Ted
Las Vegas, NV
2022 Lariat LR
My dates are estimates of when I thought I saw those numbers. I did get some recall software changes done on May 5th, so the timing is in the ballpark.
Mileage
MTBAZ
Dan
AZ
22 Lightning Lariat
22 LR Phoenix AZ truck. Never inside.
32,000 miles.
48A L2 to 80% 99% of the time
DCFC - maybe a dozen times
Charged to 100% maybe 3 times a year.
SOH - 98.5%
Maxx
Maxx
NIce ........ I corrected the thread title TYPO...... carry on.
Thanks.
I worked on learning this language for a few decades before I gave up.
electricpig
Tim
Northwest Arkansas
I forgot to specify, Level 2 charging is what I've seen specified when going from near zero (below 5%) to 100%.
Let us know the results of you do this Good luck.
Kniaz
Ivan
CA
F-150 lightning lariat ER CarboneGray
23 LR ER Sacramento CA truck. Never inside. 18 months
65.321 miles.
80A 17.6kwt L2 to 100% of the time every day
DCFC -1 time per week
3 times discharge 0% stay too line street . my wife came and charged me with her truck (same white color)
SOH - 99.52%
Maxx
Maxx
SOH - 99.52%
what do you use to see SOH with that level of detail? My car scanner shows me only to one decimal point and even that is only 0 or 5.
jimfigler
Orchard park, NY
someone on Facebook reported the app gave 100% SOH when he had a bad module, so I take zero faith in that number.
Kniaz
Ivan
CA
My real range 240-252-268 miles. 80% highway 75 speed. Ful load staff 700 pounds
