Eos Backup & Battery TX
CharlieV2X
Texas, USA.
www.eos-e.com
Does the Sigenergy system work without the battery? Like can you buy just the gateway, controller/inverter, and the bidirectional DC charger and use the lightning as the only battery?
Hey Petah, yeah, they work without a battery. Still needs a floor or wall base. But you can add a battery at a later date. Caveat it won't give you the advertised throughput because it supplemented itself with the stored energy from the battery. It's kind of like DEF fluid.
Pitbull2o08
Ohio
I’ve been interested in sigenergy because it works with other EV’s as well. I just could never conceptualize what the install would look like on my wall. Do you have a photo of the single stack all complete on one wall?
CharlieV2X
Texas, USA.
www.eos-e.com
I’ve been interested in Sigenergy because it works with other EV’s as well. I just could never conceptualize what the install would look like on my wall. Do you have a photo of the single stack all complete on one wall?
No kidding about it being really flexible
Ford F-150 Lightning Ford HIS is dead. Here's what F-150 Lightning + Charge Station Pro owners can actually do for V2H in 2026. 1 hero pic
Ford F-150 Lightning Ford HIS is dead. Here's what F-150 Lightning + Charge Station Pro owners can actually do for V2H in 2026. 2 stack in garag
Ford F-150 Lightning Ford HIS is dead. Here's what F-150 Lightning + Charge Station Pro owners can actually do for V2H in 2026. loadhub and stack indoor
Ford F-150 Lightning Ford HIS is dead. Here's what F-150 Lightning + Charge Station Pro owners can actually do for V2H in 2026. 1 n 1 stack
Ford F-150 Lightning Ford HIS is dead. Here's what F-150 Lightning + Charge Station Pro owners can actually do for V2H in 2026. Sigen EV DC Charging Module Left Semi-transparent Cable (1+1+2)
Newton
WA State
If I had a battery system at home I think that I would simply hook the 7.2kW in the truck bed to the battery‘s charger when it was necessary. The mains connection could just be a plug, or you could go fancy and have a relay with utility power hardwired and a plug for the Lightning (biased towards utility power).
What are the disadvantages of that compared to a full bidirectional setup?
Waffle
CA
2023 Lightning
Thank you for this write up and information. I’m working with a local solar company for a new solar and battery system and they recently started selling SigEnergy but don’t have many installs yet, so it’s good to see your confirmation of Sig. The features are compelling, especially for Ford Lightning owners. In addition to everything you mentioned, the SigEnergy 25kW charger is DC (unlike the Tesla home charger) so no loss due to DC to AC conversion.
CharlieV2X
Texas, USA.
www.eos-e.com
if you go that route: when the truck supplies it, the propulsion system stays partially active to support the onboard inverter, cooling fans, pack thermal management, electronics cooling all kick on. So there's a parasitic draw beyond the actual load you're pulling.
unshortness
Peter
Hamilton, Ontario, Canada
2024 Lightning Flash
My understanding is the bi-directional charger will work with all lightnings regardless of weather they have the 9.6kW ProPower, and also it can pull up to 25kW, when the plug in the bed is limited to 7.2kW. Those of us with larger peak electric loads can still take advantage of this. Also it can push / pull electricity back and forth whenever without you having to plug into the bed and turning the truck on.
Oh, but as the inverter is only rated for 11.5 kW even though the bi-directional DC charger is rated for 25 kW the only way to extract 25 kW from the lightning is to have Sigenergy batteries and charge them while also using the inverter.
I have a 2024 Flash without ProPower and on the coldest days my Heat Pump alone can pull more than 7.2 kW so I'm very interested in this, especially now that I know using a battery is optional and easily added later.
tearitupsports
Russell
Cypress, TX
The Pro Power onboard cannot start large loads. It has absolutely no surge capacity.
As noted not all Lightnings have it either.
Sigenergy will work with any year and trim level of Lightning
Also as noted it should be considered 11.4kW for both charge and discharge. Sigenergy advertising 25kW is a gimmick and would be very short term requiring a sizable solar and/or battery capacity in the same inverter stack.
I love my Sigenergy system. It works amazingly well especially having come from a ProPower and then home integration solution. I have had all 3.
CharlieV2X
Texas, USA.
www.eos-e.com
Are you speaking of the older strategy where you have to leave the truck on all the time for ppob to work? The 25 ym you don't have to leave the truck on to use ppob.
Real improvement! Still a different layer. Whenever PPOB is actively supplying load, the truck still runs cooling fans, pack thermal management, and electronics cooling to support the onboard inverter doing the DC-to-AC conversion. The 2025 wakes that stack automatically instead of asking the driver to keep the truck on, but the loads themselves don't disappear; they're still pulling from the pack whenever AC is flowing off the bed outlet. So the UX is cleaner. The energy budget around what the truck consumes to deliver PPOB hasn't changed.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
I could probably come up with a very affordable device to send the RS-485 signal to the FPCS to turn on the DC. Then anyone could use the DC for whatever they want. Would this be valuable to the community?
nate002
nate
‘24 Flash | Antimatter Blue | 9.6kW Pro Power
I’d love you forever, for whatever that is worth.
harlano
Cali
2015 Fiesta ST, 2023 Lighning XLT ER,2024 Maverick
1/2 retired
Yes, I would definitely use it. I have the expertise to do this as well but don’t access to an HIS to sniff the communications.
I would greatly appreciate this.
unshortness
Peter
Those of you with Sigenergy experience, I already have a 5 kW SolarEdge inverter with just over 5 kW of solar with Solaredge Inverters. I know It would be cheapest to leave this alone if I add the Sigenergy gateway/transfer switch, the Sigenergy Inverter, and the Sigenergy DC charger, but I know the sigenergy inverter has built in MPPTs. Do you have any recommendations on how my system could work if I left the solaredge optimizers and connected the solar to the sigenergy inverter? Or would I have to also buy and install the Sigenergy microinverters to make this work? And is this even worth it at all or should I just leave the solaredge system connected to my main panel and leave well enough alone.
