EV Connect at Ford dealership
Jameshoffee11
James
VA
Ford lightning flash
Dolphin Trainer
I stopped by my nearest Ford dealership to try the charging they had. It was EVconnect with a Blue Oval sticker on the base of the charging unit. I could not charge. Whether I used the Ford app or the EVconnect app, I could not find the 6 digit identifier the apps used, none of the 3 charging stations were labeled with the identifier. The charging units, Autel if i remember correctly, were not listed as plug and charge in the ford app and did not start charging just with a connection to the truck. :sadface:
tubby
Press
Iowa
I found this, not sure if it is correct.
If you cannot find the physical sticker on the station housing or near the screen, you can initiate the charge directly through the app's GPS map:
  1. Open either the FordPass app or the EV Connect app.
  2. Open the Map/Station Finder and let it locate your exact position.
  3. Tap on the Ford dealership location you are currently visiting.
  4. The app will pull up the specific location profile and list the individual charging pedestals active at that site.
  5. Select the specific charger you are plugged into from the list and tap "Start Charge" or "Activate" directly from your screen.
Note: If the station isn't showing up on the map and has no physical ID labels, it may not be fully commissioned or provisioned on the commercial network yet by the dealership. In those instances, the unit won't accept a standard Plug & Charge command and will require dealership staff to activate it internally.
JayF
Jay
Tacoma, WA
jay.jvf.cc
2023 F150 Lightning Lariat SR
Open Source Developer
I make a point to look at dealerships as I'm passing by to see if they would be viable charging stops.
Titus-Will Ford (where I bought mine) in Tacoma? Their DCFC was broken, so they gave me delivery of my truck with something around 30% battery. The AC charger was partially ICE'd as well. The people in the dealership seemed happy the DCFC was broken because they were glad there weren't Rivian drivers everwhere.
I was driving down the road, passed another Ford dealer -- one ABRP had wanted me to charge at. I look from the highway: you can clearly see the chargers are ICE'd.
I know it's probably a "luxury" of the PNW and the charging availability up here, but I don't think I'd *ever* count on being able to charge at a dealer.
potato
BC, Canada
2023 F150 Lightning XLT ER
It’s ironic but of the two or three Ford dealerships I’ve stopped to charge at, none of them had plug n’ charge ability.
Tesla is the only one who truly understood that seamless public charging is REQUIRED to get people on board with EVs. Everyone else treats it like an afterthought.
Charge_Rob
2024 F-150 Lightning Lariat
Charging Nerd
Ford dealers have chargers from a huge range of providers.
At around 400 dealers, they have Ford Charge as their charging provider - and Ford Charge is Plug & Charge enabled. If you're at a Ford Charge dealer and you don't have Plug & Charge working, that's an actual problem. At the rest of the dealers, you'll need to use the Ford app to pay with your BlueOval Charge Network account until those providers themselves add Plug & Charge.
Charge_Rob
Charging Nerd
Can you let me know what location (either here or DM)? Happy to reach out to them to see if we can get this fixed.
At Ford dealers, right now those with Ford Charge equipment are Plug & Charge. The rest are a wide mix of equipment and networks, none of which have Plug & Charge but all should be in BlueOval Charge Network so you're doing the right thing using the Ford app at this EV Connect location.
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
There’s a good reason that PlugShare has an option to hide dealership locations. They are for emergency use only.
djwildstar
Guy
Atlanta, GA
2023 Lightning Lariat ER, 2023 Mach-E GTPE
Information Security
It isn't just the Pacific Northwest -- don't ever count on being able to charge at a dealership.
At best, dealerships consider the chargers to be a convenience that they might offer to their own customers. However, most dealerships would prefer that EVs not exist, and will take steps to ensure that any chargers they might have been required to install aren't actually usable -- either by ICE'ing them in, or by setting the cost to the maximum possible.
I stopped several years ago at a brand new DCFC at a FORD dealer, I wanted to give a try, but apparently the dealer was using it more for parking spaces, versus allowing owners to easily access it... but, I was still able to 'squeeze' my truck in a space and get started...
I went inside the dealership, used their facilities someone pointed me to, and came out to find someone stalking me...
he walked up, stared at me, and asked if I was the LIGHTNING charging at 'their' charger... of course I was... I told them I really appreciated it, too...
surprisingly, he immediately told me that it was 'their' charger, and ONLY for the dealership's own vehicles...and NOT for owners, or even their own CUSTOMERS.... uh, what??
He then harshly pointed out that a charger for the 'public' was WAY OUT at the very edge of the parking lot, near the highway. As I looked that way, I realized what he was pointing to - and I had driven in right past it coming in, although it was in the opposite direction of where I was looking, according to Google Maps. Google maps, and even the FORD app, pinned it at the 'dealer' location unit. Apparently, they didn't know this, either.
O.k., so, well," I appreciate that, and I'll use that one next time... in the meantime, since I'm already charging now, I'll be leaving 'your' charger, soon." He huffed off quickly.
By the way, his was free. The 'public' charger was not.
I haven't stopped there since, and don't plan on it.
Now, there are not only the EA units nearby, and our option to use Superchargers up the road, but even more new Chargers at Pilot/FlyingJ, and faster, since these were installed. Oh well.
I've never understood some Ford and most Hyundai's "these are our chargers" mentalities, when MERCEDES, and CHEVY dealers, and yes, even KIA, embraced me many times at theirs.
Charge_Rob
Charging Nerd
I'm sorry you've had that experience - it's not been mine, I've charged at dozens of Ford Charge dealers across the country and never had a problem. And now with Plug & Charge it's even easier. Plenty of dealers have invested in making charging a great experience, I wouldn't want to generalize that they're for emergencies - I plan my road trips around dealers with great experiences and haven't been let down yet.
Charge_Rob
Charging Nerd
Sounds like they offered public charging, just not public free charging? Most don't offer free charging, for very understandable reasons.
I've charged at dozens of Ford Charge dealers across the country and haven't had those issues. Sometimes PlugShare users do add the dealers' private non-public chargers, if you see those you can report them for removal.
Charge_Rob
Charging Nerd
Looking at my charge logs, I've charged with Ford Charge 41 times at dealers in West Virginia, Maryland, Delaware, Pennsylvania, Ohio, Michigan, Illinois, Wisconsin, and North Dakota. I wouldn't write them off. Especially now with Plug & Charge.
Sometimes there's amenities just a step away:
Ford F-150 Lightning EV Connect at Ford dealership 1779311049893-9
Or a oasis in West Virginia:
Ford F-150 Lightning EV Connect at Ford dealership 1779311060754-x
Or cheaper than the Tesla down the street:
Ford F-150 Lightning EV Connect at Ford dealership 1779311037723-m0
