Mike G
- First Name
- Mike
- Jan 6, 2022
- N. AL, USA
- 2022 F-150 Lightning, 2023(J1) Mach-E GT-PE, '24 Bronco HLE 2Dr
This is the one I use. And apparently it's -20% off for a limited time (as of the date I posted this).If you want a really accurate test of the battery without special equipment, you would need to disconnect it, fully charge it, note the terminal voltage with a voltmeter, let it sit for several hours (overnight), then use the voltmeter to measure the terminal voltage again - if it drops a lot from the fully charged measurement, then it has issues.
Of course you can get even more info using a battery tester, like CCA (Cold Cranking Amps), State of Heath, resistance, etc.
