Rotary Shifter Part Numbers
Space Flash
Richard
2025 F-150 Lightning Flash
Installed the injection molded rotary shifter adapter and the rotary shifter from ManionMakes in our '25 Flash a couple of weeks ago. Works like a champ and looks totally OE. Only another Lightning owner would know that it didn't come from the factory like that.
The shifter is motorized and illuminated. If I shut the truck off without taking it out of gear it automatically puts it in park. The drive and neutral hold letters light up and the dial has a nice blue ring when the headlights are on.
Installation went without a hitch. The adapter's fit and finish are perfect.
The shifter I received was brand new. PN: LX6Z-7P155-U
Highly recommended!
Ford F-150 Lightning Rotary Shifter Part Numbers Lightning ManionMakes Rotary Shifter
Robocop
2022 Platinum; 1962 Lincoln Continental
holy crap! this is quite an update.
so the injection moulded part doesn't require any finishing at all? so plug and play? that looks amazing.
Dahveed
Salina, Kansas
2025 Ford F-150 Lightning Flash (Job 2)
Yup. It looks absolutely OEM. Only thing missing is a little rubber pad for the bottom of the storage compartment. The one from the original shifter is contoured and doesn’t lay flat.
mt2525
Michael
2022 F150 Lightning XLT 2024 Cadillac Lyriq
Just received this part #JX6P-7P155-FG mounted in the conversion piece from Etsy. Before I attempt upgrade has anyone used this particular part number?
Mike G
N. AL, USA
Has Ford assigned the ManionMakes injection molded version a part number yet? :)
I'm still rockin' my original 3D printed version, but the new one looks very nice! I might have to upgrade.
Fifty50Chance
Chance
2020 Honda Fit
Edit: I'm an idiot! When you plugin the shifter you need to pull the gray piece back to lock it in. I'm leaving this just in case someone else makes the same mistake. It is working fine and looks great
I swapped and got an error. So swapped back and now I'm getting an error any my truck is stuck in the driveway!"
In November I purchased a JX6P-7P155-U (Ebay) and finally decided to install it today. Install on an XLT was more of a pain than expected but I was able to figure it out. When I started it up I got the error above. The shifter did nothing.
So I swapped the original back in. It is in the stow position and same error. Shifter is stuck down.I can't move the vehicle.
I looked at the shifter and it looks like I received the wrong part JX6P-7P155-FE. This is my fault for not looking at it when I got it but I'm annoyed I looked at the listing and I have the right one.
If anyone has any ideas how to just get my truck moveable again!
Fixed see edit at top
Space Flash
Richard
We’ve all been there, done that at some point. šŸ˜‰ Glad you got it sorted! šŸ‘
Keep the shiny side up! šŸŽ
kubel
US
2024 Ford F-150 Lightning Flash (+9.6kW PPO, Max Tow)
LX6P-7P155-EH from ebay might ship out a non-motorized version that doesn't feel very good.
Edit: Looks like ebay seller "manufacture-factory" shipped the wrong part, MZ9P-7P155-AA, which is a free spinning (non-gated) non-motorized version, and is now claiming they are all the same part. Buyer beware. It works. And it's probably going to be more reliable. So I don't know if I should just keep it...
Ford F-150 Lightning Rotary Shifter Part Numbers IMG_20260727_180259
Finished product:
Ford F-150 Lightning Rotary Shifter Part Numbers finishedproduct
My final thoughts: I'm agnostic.
Pros:
Looks stock
Gets rid of a failure prone part
Allows for work surface to be lowered while in gear
Easy mod to do
Cons:
$100 for a piece of plastic is pricey
It's becoming more difficult and expensive to source rotary shifters
I find myself selecting the wrong gear a lot
My biggest concern was that I would miss the shifter as a place to rest my hand, but that turns out not to be the case. I just put my elbow back a little more and my fingers rest just ahead of the arm rest.
So to be clear:
- A non-motorized shifter allows you to "spin right", or "spin left", not worrying if you overspin, because it doesn't matter.
- A motorized shifter stops on D, or P, gives a more "secure" feeling to people.
But, either one works fine, and both shift to P if you shut off the vehicle without shifting to Park.
Correct?
Next question:
My 2022 shifts to P when I open the door. So does my Mach-E. What is the experience of people here, and does it differ between motorized and non-motorized, or model years?
Space Flash
Richard
So to be clear:
Correct?
Next question:
Have the ā€œmotorized shifterā€. Stops at P and D. Automatically shifts to P when turning the ignition off. Automatically shifts to P if I open the door. More here:
https://www.f150lightningforum.com/...hifter-part-numbers.29588/page-16#post-726667
Mike G
N. AL, USA
There have been some reports that some of the non-motorized shifters used on the Mach-E throw a DTC when used in the Lightning. I have two of those, one brand new, and the other someone sent me, but my currently installed shifter that works perfectly and has never ever thrown a DTC came from an Ebay seller who parts out vehicles, and it was a motorized shifter with the rubber ring, and it came out of a '21 Bronco Sport. It also has the lighted ambient blue ring at the base of the knob that you can really only see at night...but that's also obviously when it would be most useful.
So to be clear, in my experience, it's more important to know what vehicle the shifter came out of rather than what specific part number it is. And I think I posted the part number of the one I installed waaay back when I did the mod, so I won't do that again here now.
I do intend to spend the money on the new injection molded version of the GSM bucket to increase the overall perception of OEM quality to the mod, and also to support the ingenuity and enterprise of ManionMakes for filling a need that Ford didn't want to take on.
AlbertaMike
Edmonton, Alberta, canada
2023 Lariat SR
I’m compiling a verified list of Ford rotary shifter part numbers.
The current working theory is that part numbers starting with LX6P or LX6Z typically refer to motorized rotary shifters. These are commonly used in 2020–2022 Escape, Bronco Sport, and others.
I’m hoping to collect real-world confirmations so we can build a reliable cross-reference list for retrofits and replacements.
If you’ve used one of these parts, please reply with the following:
  1. Part number (example: LX6P-7P155-EH)
  2. What vehicle it came from (year and model)
  3. Whether it is confirmed to be motorized (yes/no)
  4. Any other notes (source, behavior, fitment issues, etc.)
LX6P-7P155-XX believed to have the blue light in dial base (ring)
Motorized Rotary Shifters
These rotary shifters have a built-in motor that automatically rotates the knob into "Park" when the vehicle powers off.
Part NumberConfirmed ByNotes
LX6P-7P155-ED—Believed motorized
LX6P-7P155-EE@AjzrideConfirmed motorized
LX6P-7P155-EH@Drayday55Confirmed motorized, has ā€œLā€ button
LX6P-7P155-HE@jmyer72Confirmed motorized, has ā€œMā€ button
LX6P-7P155-HG@digitaldadConfirmed motorized
LX6P-14G395-AB@AjzrideConfirmed motorized
LX6P‑7P155‑AD@RobocopConfirmed Motorized
LX6P-7P155-LE@Mike G @sstevetxConfirmed Motorized
LX6P-7P155-LD @Poster_NutbagConfirmed Motorized w/ Ambient
LX6Z-7P155-A/ABMeConfirmed Motorized w/ Ambient
LX6Z-7P155-U@JimH05Confirmed (Do not buy from Multisurplus on Ebay)
LX6Z-7P155-BBelieved Motorized
LX6Z-7P155-MBelieved Motorized
LX6Z-7P155-X @T3FanMotorized/Rubberized ring/ w/ ambient
Non-Motorized Rotary Shifters
These do not physically return to Park; the knob will physically rotate past Drive (without continuing to change gears).
PZ1P-7P155-AC@The WeathermanNon-motorized, has lit base
PZ1P-7P156-ED @DIEProphezeiungNon Motorized - Lit base
LJ9Z-7P155-D@farmtruckNon-motorized, from 2021 Mach‑E
NZ6P-7P155-AD@mr.MagooNon-motorized, Maverick
PZ1P-7P155-HC@mr.MagooNon-Motorized, Escape, has Ambient
PZ1P-7P155-EG @GaunleBronco Sport 2024 has ambient
NK4Z-7P155-D@mr.MagooE-Transit
Check out @Mike G 's install method here - This is the best way I have seen it done so far if you care about keeping all your clips intact.
Please add any others you’ve verified, or correct anything above if you’ve found otherwise. Once we gather enough data, I’ll update the first post with a full list of confirmed motorized part numbers.
Worth a read before ordering to make sure you get the updated part https://www.macheforum.com/site/thr...pressed-transmission-remains-in-park-p.21849/
Thanks in advance for contributing.
I installed and working well:
PZIZ-7P155-AM
non motorized
Ambient light, chrome knob
From 23 escape is what Ford dealer told me
