Will Ford publish KWh/100 miles?
Fordskeptic
Chevy
631Belle#
Chevy, toyota, honda, jeep
Will Ford publish expected energy efficiency of F150L? I haven't seen any. If you have, please post a link. For now, what's everyone's guess? My guess is 50 kwh/100miles.
Fordskeptic
Chevy
631Belle#
An earlier thread had a 46-50kwh/100 miles. So I will use that until Ford says different.
sotek2345
Engineering Manager
I have seen similar estimates elsewhere (usually given as 2mi/Kwhr). I think these are largely based on battery size estimates and range.
TRP
Tim
TN
2021 Mach E Premium 4X, 2018 Ford F150xlt Sport
I don't think the Lightning has gone through the EPA testing, or if it has, Ford has not released the results........just estimates
Fordskeptic
Chevy
631Belle#
Rough numbers, I figure F150L vs my current ICE vehicles saves about $0.09/mile fuel and $0.01/mile maintenance so say $0.10/mile. Anyone done similar rough calcs?
shutterbug
Phoenix
Fuel cost will vary greatly based on your cost of electricity. My TOU rate is about $0.0523/kWh. There are people that are paying several times that.
sotek2345
Engineering Manager
Hmm.. I did the math on a per month basis ($100/mo. for me). Given my truck gets about 6k miles per year (drive my fun car in the summer), that is about $. 20/mile or double your savings. That said my truck is tuned to use premium fuel (about $3.90/gal right now) and gets about 15mpg around town....
biers
Thomas
SW Washington
2022 Pro SR upgraded to ER
Miles per kWh people, please. No one talks about how many gallons of gas it takes to go 100 miles.
the best efficiency number I can get from the charging data - specifically the miles per hour of 32A charging at 7.1 kW (240v assuming 7% loss). Math shows the ER would use 546W to go a mile and the SR 507W. Or right around 2 mpkWh on SR and 1.8 on the ER. This also shows us the available capacity for the SR should be around 115 kWh and 165 kWh on the ER.
My 3 ton Pacifica hybrid gets 2.6 mpkWh so I think these numbers are going to be pretty close given the truck is bigger, heavier and less aerodynamic. Oh. And AWD.
sotek2345
Engineering Manager
This is very much an American vs. European thing (they use L/100km). I actually think they have a better unit as it is much better at explaining relative change in a linear way (which humans are better at understanding). Here is a great video on the subject.
https://www.google.com/url?sa=t&rct...=oLQmwOX6Xds&usg=AOvVaw1INEDokD_6uGPgniYnv37T
That said, I am American, so I tend to think in mpg / miles per Kwhr too!@
Fordskeptic
Chevy
631Belle#
I guess my age and colonial roots are showing.?
Interesting that the ER is calculated to require more watts than the SR due to charging efficiency factored into the larger battery capacity. Learned something new today. I hadn't thought about it, but it makes sense.
greenne
Nathan
Niskayuna, NY
This makes sense. *Most* people in the know are guessing a usable battery capacity of 150-155KW. (extended battery). If you take 150 KW, thats 300mi based on 50 kwh/100mi, slightly more at 46kwh/100 mi
diesel97
rob
Ford Edge
electrical
Nobody might be talking about it but it is on the window sticker and is a better way to compare MPG
