Figuring actual miles/kwh
seajai
chris
2025 F150 Lightning Flash
Tile installer
My EVIQO charger app shows how much power was delivered for the charge session. This is always higher than the Ford app shows, which I assume is due to efficiency loss. So which number would I use? For example, my last session showed 32.8kwh from the charger and 30.6kwh on the Ford app. Miles driven was 60.9 which gives 1.85 and 1.98 mi/kwh respectively. My dash showed 2.0 mi/kwh.
They are both correct depending on the question you are asking. To figure overall ownership cost, I use the kWh amount the EVSE registered and miles driven. Between the wall and battery, I typically see about 7-10% loss through EVSE cable and on-board charger AC-DC conversion.
However when I'm driving down the road I don't care about those losses - I want to know what my battery capacity is (SOC) and the miles it will take me - so I need a driving mi/kWh. This is what the dash shows and what the Ford App charge session shows (kWh into battery).
Ditto what @bmwhitetx said. Most of the time, mpk discussions refer to efficiency while driving. Taxman and a few others report their cost efficiency as well.
BartBB
Bart
F-150 Lighting Flash
Contractor
Easier math for actual driving range is a mental note of the terrain to travel and the mile/%. In flat and slower travel I've been close to 3 miles per percentage point. Faster and hills get me down to 2.5 ish.
